Finding the Phase Constant of a Sinusoidal Velocity Graph
  • Thread starter Thread starter bcjochim07
    Constant Phase
The discussion revolves around finding the phase constant of a sinusoidal velocity graph, characterized by a period of 12 seconds and a maximum velocity of 60 cm/s. The initial velocity at t=0 is -30 cm/s, and the velocity returns to -30 cm/s at t=12 seconds.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between amplitude, angular frequency, and the phase constant. Some attempt to derive the phase constant using the sine function, while others express confusion over multiple possible angle solutions and their implications for the graph's behavior.
Participants are actively exploring different interpretations of the phase constant and its calculation. Some guidance has been provided regarding the use of amplitude and angular frequency, but confusion remains about which angle corresponds to the correct phase constant based on the graph's characteristics.
There is ongoing uncertainty regarding the definitions of amplitude in the context of velocity versus displacement, and how this affects the calculations for the phase constant. Participants are also grappling with the implications of multiple angle solutions from the sine function.
bcjochim07
Phase constant --Please help me!
What is the phase constant?
The picture didn't come yet but here's a description:
It is a velocity vs. time graph. It is sinusoidal with a period of 12 s and a max velocity of 60 cm/s. The inital value for velocity at t=0 is -30 cm/s and the value for velocity at t=12 is -30 cm/s
First I found A vmax= 2pi*A/T
60= 2pi*A/12 A=114.6
ok so I tried vo= -omega*A sin(phase constant)
omega= 2pi/T 2 pi/ 12 = pi/6
-30 cm/s = -(pi/6)*114.6 sin(phase constant)
I found phase constant = .5235 rad, but that's not right
I know that there is another angle that has the sine value, but how do I know which one is the phase constant
I am really having trouble with the phase constant
Could someone help me out?
Your amplitude, A, corresponds to the maximum velocity, which in this case is 60cm/s. Your period is 12s, so by using T = 2*pi/w, in which w is angular frequency, you could find the value for w. Since you know the amplitude and angular frequency, and you know that the general form for the velocity is v = -A*sin(wt + phase constant), all you have to do is plug in numbers. At t = 0, v = -30cm/s, and since you already know the amplitude and angular frequency, you could solve for the phase constant.
Right, I think that's what I did up above, but I got the answer wrong according to mastering physics. I've checked it several times, and I don't know why it's wrong.
.49996= sin(phaseconstant)
arc sin (.49996) = .52355 rad or 2.618 rad I don't know which one is right because at both position the particle would be moving to the left ( have a negative velocity initially like in the graph) This is what is confusing me.
The amplitude is 60 cm/s.
oh, so for the velocity formula, you have to have A in cm/s...ok I see
so .955=sin(phase constant)
phase constant = 1.27 rad ?
v=60*sin(wt+phase). At t=0, v=-30. Put that in. -30=60*sin(phase). sin(phase)=(-1/2). Isn't that what you want?
My book says the formula is v= -omega* Asin(omega * t + phaseconstant)
Your book's formula is using the amplitude of the displacement. For this question we are using the amplitude of the quantity in the graph you showed us. That would be the velocity amplitude, 60 cm/s.
Displacement, velocity, and acceleration each have their own amplitude. We need to be clear on which one we are using.
so if I used that formula in my book, then shouldn't I come up with right answer as long as I use the amplitude from vmax=omega*A, where A is in cm. I chose to use the amplitude for displacement, so shouldn't that yield the same answer? I'm really confused about this.
Yes, you are confused. If the amplitude for displacement is A, then yes, the amplitude for velocity is omega*A. But omega*A=60 from your graph. Since it's a graph of velocity. So A=60/omega. Hence the amplitude for velocity is omega*A which is omega*(60/omega). Which is 60. Which is where we started. This is making my head hurt. Can you make it stop?
I'm sorry...
Ok, so I was doing exactly what you are telling me aways up above until I got confused about the amplitude.
I wrote: .49996= sin(phaseconstant)
but the problem I was having was what value of the angle is the phase constant since arcsin .49996 gives two angles, both of which would be moving left like indicated in the graph.
Ok, but shouldn't sin(phase) be -0.5, not +0.5? And yes, there are two really different values modulo 2pi. But only one increases the velocity as t increases from 0. Look at your diagram. There are two different points where the velocity is -30. But only one fits your diagram.
  • · Replies 42 ·
