Calculating the travel time in relativistic travel
This discussion focuses on calculating travel time in relativistic travel for a spaceship, considering variables such as empty mass (MSS), distance (RAB), fuel mass (MFUEL), energy per mass (EPM), engine efficiency (SEP), fuel burn rate (FPS), and interstellar medium friction (IMD). The user derives equations for spaceship power (SSP) and total mass before and after relativity (TMBR and TMAR). The conversation also addresses the integration of IMD into the equations and seeks guidance on solving the resulting differential equation.
  • Understanding of relativistic physics concepts, particularly time dilation and mass-energy equivalence.
  • Familiarity with differential equations and their applications in physics.
  • Knowledge of energy calculations in propulsion systems, including efficiency metrics.
  • Proficiency in using mathematical software like Maple for solving complex equations.
  • Explore the implications of relativistic mass changes on acceleration and travel time.
  • Learn how to integrate differential equations, particularly in the context of physics problems.
  • Investigate the effects of interstellar medium friction on spacecraft dynamics and energy consumption.
  • Study advanced propulsion systems and their efficiency in interstellar travel scenarios.
Astrophysicists, aerospace engineers, and students of physics interested in the complexities of relativistic travel and spacecraft dynamics.
rhz_prog
A spaceship with empty mass MSS(?kg), start its journey from A to B which distance is RAB(?ly). The amount of fuel the spaceship
initially carry is MFUEL(?kg), which energy per mass is EPM (?Joule/kg). The spaceship engine efficiency is SEP (?%), and the engine is capable of burning FPS (?kg/s) mass of fuel per second. If the interstellar medium friction constant is IMD (?/s), calculate :
1. The maximum cruising speed ? (SRF and IRF)
2. Length of acceleration and deceleration phase ? (SRF and IRF)
3. Length of constant cruising speed ? ( I expect it to be harder if
there is IMD ). (SRF and IRF)
4. The heat generated by friction ?
5. How the question may look like if we add the energy required to
support the crew which is ESC (Watt) into the problem ?
SRF = Ship's Reference Frame
IRF = Inertial Reference Frame
Here is where my math work had progressed so far :
Look in the variable definition above, in order to understand what
each variables in the equations below means.
So SSP = SEP*EPM*FPS ... (1)
Since (SSP=Space Ship Power) is defined as, the amount of energy the
space ship is capable of produce per unit of time, and energy means
the capability to move a mass M as far as H, using certain amount of
acceleration A, that means :
SSP = TMAR*A*H/dt = 0.5*TMAR*A^2*t ... (2)
TMAR : Total Mass After Relativity.
Which is defined as :
TMAR = TMBR/sqrt(1-(v/c)^2) ... (3)
TMBR = MSS + MFUEL - FPS*t ... (4)
TMAR : Total Mass Before Relativity.
So, I subtitute SSP from (1) to (2) :
SEP*EPM*FPS = 0.5*TMAR*A^2*t , move A^2 from right hand side to left
hand side :
A^-2*SEP*EPM*FPS = 0.5*TMAR*t, move SEP*EPM*FPS from left hand side
to right hand side :
A^-2 = (0.5*TMAR*t) / (SEP*EPM*FPS) , flip both side
A^2 = (SEP*EPM*FPS) / (0.5*TMAR*t) ... (5)
Then I subtitute TMBR from (4) to (3) :
TMAR = (MSS + MFUEL - FPS*t)/sqrt(1-(v/c)^2) ... (6)
Then I subtitute TMAR from (6) to (5) :
A^2 = (SEP*EPM*FPS) / (0.5*(MSS + MFUEL - FPS*t)/sqrt(1-(v/c)^2)*t)
A^2 = (SEP*EPM*FPS* sqrt(1-(v/c)^2)) / (0.5*(MSS + MFUEL - FPS*t)*t)
A = sqrt((SEP*EPM*FPS* sqrt(1-(v/c)^2)) / (0.5*(MSS + MFUEL -
FPS*t)*t))
Since A = dv(t)/dt, the problem become this differential equation :
dv(t)/dt = sqrt((SEP*EPM*FPS* sqrt(1-(v(t)/c)^2)) / (0.5*(MSS + MFUEL
- FPS*t)*t))
Written down in Maple Format :
diff(v(t),t) = sqrt((SEP*EPM*FPS* sqrt(1-(v(t)/c)^2)) / (0.5*(MSS +
MFUEL - FPS*t)*t));
So, did I do something wrong ?
Where should I put the IMD (Interstellar Medium Friction Constant (?/s)) into the equation ?
Is there a way to integrate the differential equation ?
  • · Replies 36 ·
10K
  • · Replies 65 ·
14K
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 75 ·
  • · Replies 42 ·
10K
  • · Replies 18 ·
