Calculating Fermi Level in Doped Silicon at Room Temperature and 0K
  • Thread starter Thread starter andarr
    Fermi Fermi level
The discussion focuses on calculating the Fermi level in doped silicon at room temperature and absolute zero (0K). For a silicon crystal doped with 1015 cm−3 phosphorus atoms, the electron concentration is determined to be 1.96 x 105 cm−3 and the hole concentration is 1015 cm−3. The Fermi level can be calculated using the equation Ef = [(Ec + Ev)/2] + [(kT/2) ln(Nc/Nv)], where Ec is the conduction band edge energy. At 0K, the intrinsic carrier concentration (ni) is needed for accurate calculations.
  • Understanding of semiconductor physics, specifically doping effects in silicon.
  • Familiarity with Fermi level calculations and related equations.
  • Knowledge of intrinsic carrier concentration (ni) in silicon at different temperatures.
  • Proficiency in using the Boltzmann constant (k) in thermal energy calculations.
  • Research the intrinsic carrier concentration (ni) of silicon at 0K.
  • Learn about the conduction band edge energy (Ec) and its significance in semiconductor physics.
  • Explore the effects of temperature on electron and hole concentrations in semiconductors.
  • Study the derivation and application of the Fermi-Dirac statistics in semiconductor materials.
This discussion is beneficial for students and professionals in semiconductor physics, electrical engineering, and materials science, particularly those involved in doping silicon and analyzing its electronic properties.
andarr
(a)If a silicon crystal is doped with 10^15 cm−3 phosphorus atoms, find out the electron
concentrations and hole concentrations in the silicon at room temperature. Find
out the Fermi level.
(b)Repeat at temperature = 0K
n*p=ni^2
n=2(2pi(n*)kT)^(3/2)exp-[(Ec-Ef)/(kT)] where (n*) = electron effective mass
I have calculated the hole concentration p = 10^15 per cm^3
and the electron concentration n = 1.96*10^5 electrons per cm^3
but I am not sure where to begin for calculating the fermi level. I don't know what to plug in for Ec the conduction band edge energy. For part (b) I am also unable to find ni, the intrinsic carrier concentration of silicon at T = 0K. Any suggestions or insight would be appreciated, thanks in advance.
Ef=[(Ec+Ev)/2]+((KT/2))ln(Nc/Nv):if n=p=ni
and i think that you can use Eqs:
Ef==KT*ln{[(1/4)*[e^(Ed/KT)]*([(1+(8Nd/Nc)e^(deltaEd/KT))^(1/2)]-1)}
