Can Electric Motors Match the Power-to-Weight Ratio of Human Muscles?
The discussion explores whether electric motors can achieve power-to-weight ratios comparable to human muscles, considering theoretical possibilities, engineering challenges, and efficiency comparisons. Participants examine various aspects including torque variability, energy storage, and the efficiency of biological systems versus mechanical systems.
  • Some participants propose that with proper engineering, electric motors could theoretically match the power-to-weight ratios of human muscles, suggesting that increasing voltage could enhance power output.
  • Others argue that while electric motors may be more energy efficient, the current energy storage technology (like batteries) is inferior to biological systems.
  • Concerns are raised about the efficiency of human muscles, with some participants noting the significant caloric intake required for physical labor and questioning the overall efficiency compared to electric motors.
  • Participants discuss the complexity of using motors for tasks like gripping, suggesting that motors may not be as versatile as biological muscles in varying torque and speed.
  • There is mention of research into synthetic materials that could mimic muscle function, potentially impacting future robotics.
  • Some participants highlight that motors are not inherently linear in their power application, which could affect their performance compared to human muscles in practical applications.
Participants express differing views on the efficiency of human muscles compared to electric motors, with no consensus reached on whether electric motors can match the power-to-weight ratio of muscles. The discussion remains unresolved regarding the comparative efficiency and practical applications of both systems.
Participants mention various assumptions about energy consumption and efficiency, including the caloric requirements of humans and the mechanical efficiency of muscles, without resolving these complexities.
Jake
Is it possible for electric motors to compare to the strength of human muscles, in terms of power-to-weight ratios? That is, with the proper engineering, is it theoretically possible? I don't see why not, simply increasing voltage increases power, if the heat generated is a problem, can't the motor be engineered to withstand the temperatures? Or does it have something to do with how muscles can vary torque/speed at will but motors can't?
Although I'm not 100% sure, I would imagine that as far as power-to-weight goes the answer would be yes. However, as far as efficiency goes, the answer is no.
CS
I think it is possible but more complex, using a motor for a gripper instead of a pneumatic or hydraulic actuator for example.
The Japanese have some robots that mimic many of the muscles of a human, and can even run. I think Aibo is one, and it's using only electric motors.
It's got a box on its back though, probably batteries taking too much weight in it. So while electric motors may be very energy efficient, probably more efficient than muscles, the energy storage technology at present is inferior to that of a living organism.
Motorized gripper
http://www.intelligentactuator.com/pdf/RCP2SmallGripper.pdf
I don't know if i can agree with the efficiency of muscle.
animals and humans consume one hell of a lot of matter to generate power.
average of 3 meals a day and that is just to sustain a lifestyle of sitting at a desk and moving your fingers (obviously wrt humans and not animals. heh.)
As soon as you talk about physical labor the food requirement increases dramatically.
Then there is the water requirement.
But how much energy is that really? A normal human consumes about 3000 calories a day, which is only about 12000 joules. Physical labor requirements can push that energy requirement as high as 8000 calories, or 33 kJ.
If my calculations are correct, a 100W lightbulb can consume 33KJ in less than half an hour.
I've always been under the impression that the human body is more efficient. Here is a quick link comparing humans to cars, for example. Not sure if it is considered a reputable source though.
http://recipes.howstuffworks.com/diet1.htm
However, http://www.pubmedcentral.nih.gov/picrender.fcgi?artid=1405410&blobtype=pdf" offers some good insight to the mechanical efficiency of human muscles.
CS
You can survive quite a lot of days without eating regardless of body weight, if you consider only muscles. Surviving is another issue, it is related with the inner stability of the human body or let say sustainability, therefore if we isolate the muscles for the discussion they are incredibly efficient. Also the brain makes them more efficient if you consider walking for example. The argument might be over repeatability or let say durability. Then things obviously change.
Overall, I would say that from a net power/weight standpoint some motors can equal the performance of human muscles. From an power/energy input standpoint, human muscles are more efficient but also more affected by number of repetitions and duty cycle.
Another problem is that motors are not inherently linear in their application of power; as a general rule motors are rotational, which means you have to have a special linear stage to convert the motor's angular speed and torque into linear speed and force. This would of course be subject to certain efficiencies based on the type of stage used. It also adds a significant amount of weight to the motor assembly and could possibly make it such that human muscles are able to put out more linear power per pound than a motor/stage assembly.
i recently heard of technology that is still in research and development phase.
this is a synthetic material similar to plastic, but biobased that expands and contracts with electric pulses.
the following is from Science Daily article 'Biobased Plastic Flexes Its Muscle'
There is now significant interest in the possible use of electroactive polymers in many industrial and biomedical applications, from light-emitting diodes and controlled-release devices to artificial muscles and environmental sensors. The material is typically petroleum-based, but ARS researchers Victoria Finkenstadt and J.L. Willett showed that plant polysaccharides like starch can work just as well.
i could be grouped into large masses with similar construction to the human muscle and used in advanced robotics
The 'Calorie' commonly quoted in a food context is actually a kilocalorie.
That one is well known for dumping unsubstantiated "words of wisdom" under a false air of authority in mechanics, but his new degree in biology and associated wisdom is an impressive development indeed.
  • · Replies 17 ·
