How Do You Calculate Molarity in Diluted Solutions?
  • Thread starter Thread starter nemzy
    Molarity
The discussion focuses on calculating molarity in diluted solutions, specifically using acetic acid and sodium acetate as examples. To find the molarity of acetic acid in a 250 mL solution, one must first calculate the number of moles from the 25 mL of 1.6 M acetic acid and then divide by the total volume of 250 mL. The number of moles remains constant during dilution, as demonstrated by the analogy of balls in a cylinder; adding more solvent does not change the number of solute molecules present.
  • Understanding of molarity and its calculation
  • Basic knowledge of solution preparation techniques
  • Familiarity with the concept of moles in chemistry
  • Experience with volumetric flasks and pipetting
  • Learn how to calculate molarity from moles and volume
  • Study the principles of dilution and concentration in solutions
  • Explore the concept of equilibrium in chemical reactions
  • Investigate the properties and applications of acetic acid and sodium acetate
Chemistry students, laboratory technicians, and educators seeking to deepen their understanding of solution preparation and molarity calculations.
nemzy
Lets say you pipet into a 250 mL volumetric flask the following:
10 ml of 3e-4 M bromscresol green solution
25 mL of 1.6 M acetic acid (HC2H3O2)
10 mL of .200 M KC1 Solution
and diluted to the 250 mL mark
What is the molarity of acetic acid in this solution?
Do you calculate the number of moles in the 25 mL solution since you know the molarity, then when u get the moles you find molarity over 250 mL?
2nd problem.. Let's say you have a solution with the following:
10 mL of 3e-4 Bromscresol green solution
10 mL of .160 M sodium acetate solution
and diluted to 250 mL mark
What is the mles acetate present?
Do you calculate the # of moles over just 10 mL?
Does the # of moles stay constant even though you add more volume? I think i heard that somewhere but not sure
Chemistry news on Phys.org
Yes, this is the way we tackle the problem.
] Yes, you need to calculate the number of moles of sodium acetate in 10mL first.
Yes. Number of moles tells you the number of molecules present and the number of molecues will not change upon dilution. Let me give you an analogy. If there are 3 balls in a cylinder containing 50mL water, you cannot change the number of balls inside by adding more water into the cylinder.
  • · Replies 19 ·
11K
