Understanding Kirchhoff's Loop Rule for Inductors and Resistors
  • Thread starter Thread starter ehrenfest
    Loop
The discussion revolves around Kirchhoff's loop rule as it applies to circuits containing inductors and resistors. The original poster seeks clarification on the correct formulation of the loop rule in the context of changing current through an inductor.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the implications of current direction on the application of Kirchhoff's loop rule, questioning how to determine the correct sign in the equations presented. There is also a focus on understanding the behavior of the circuit in steady-state versus transient conditions.
Some participants have provided external resources to aid understanding, while others have prompted the original poster to articulate their own reasoning and attempts. Multiple interpretations of the problem are being explored, particularly regarding the behavior of current in the circuit.
There is a mention of the need for clarity on whether the current is increasing or decreasing, which is critical for applying Kirchhoff's loop rule correctly. The discussion also touches on the implications of a steady-state condition in the circuit.
ehrenfest
Read the image. I was always confused about this. Is Kirchhoff's loop rule here:
[tex]-L\frac{dI}{dt}+IR = 0[/tex]
or
[tex]L\frac{dI}{dt}+IR = 0[/tex]
. Please explain your answer carefully.
Well what they do in the second link is use the given fact that the current is increasing to decide what the sign must be. But the same equation should hold whether the current is increasing or decreasing. How do you decide which of my equations to use without knowing whether the current is increasing or decreasing through the inductor?
BTW, the do we know the current is decreasing here? Why?
I don't mean to be rude, but can you help me with this specific example?
please show YOUR attempt to solve this first.
explain YOUR thoughts carefully, then someone might help you.
say we go clockwise around the smaller loop starting from S and record the voltage changes as we go around. How do we get the sign of the first voltage change?
The battery establishes an initial potential. When the switch has been set for a long time, it means that it has reached a steady-state situation, i.e. the current is constant, which means di(t)/dt = ?
However there is a current and stored energy in the inductor. There is also a voltage drop across the resistor, and only across the inductor when current is changing.
If the battery is by passed, i.e. short-circuited, what then happens to the current?
  • · Replies 18 ·
