Register to reply
Heat flow problem- what did I do wrong?
by frasifrasi
Tags: flow, heat
Share this thread:
frasifrasi
#1
Apr27-08, 02:52 PM
P: 277
A long rod, insulated to prevent heat loss along its sides, is in perfect thermal contact with boiling water (at atmospheric pressure) at one end and with an ice-water mixture at the other View Figure . The rod consists of 1.00-m section of copper (one end in steam) joined end-to-end to a length L2 of steel (one end in ice). Both sections of the rod have cross-section areas of 4.00 cm^2. The temperature of the copper-steel junction is 65.0 deg C after a steady state has been set up.
View Figure at http://session.masteringphysics.com/...4/YF-17-70.jpg
1. How much heat per second flows from the steam bath to the ice-water mixture?
2. What is the length L2 of the steel section?
Now, here is my solution:
∇q = 0
Because there is only heat flux along the rod this simplifies to:
dq/dx = 0 => q = constant
along the rod.
Heat flux is defined as
q = kdT/dx
k is thermal conductivity
For constant q and k you find:
q = - kΔT/Δx
So the heat flow through the rod is
Q = Aq = -AkΔT/Δx
The heat flow is constant , That means heat flow through copper section as through steel section as through the whole rod.
1.
consider copper section:
k = 400 W/Km for copper
Hence:
Q = -AkΔT/Δx
= -4.0010-4m 400W/Km (65C - 100C) / 1m
= 5.6W
I put in 5.6, and it told me it was the wrong answer.
What did i do wrong?
Thanks.
Phys.Org News Partner Science news on Phys.org
NASA team lays plans to observe new worlds
IHEP in China has ambitions for Higgs factory
Spinach could lead to alternative energy more powerful than Popeye
Astronuc
#2
Apr27-08, 03:39 PM
Admin
Astronuc's Avatar
P: 21,808
Steel and copper have different thermal conductivities, so the temperature differentials will be different. The boiling water at 1 atm is at 100C, which is sat temp at 1 atm, and the ice is at 0C.
The interface is at 65C, and the heat flux on both sides is equal, but the dT/dx is not.
Find expressions for the heat flux in the copper and steel at the interface and set them equal.
frasifrasi
#3
Apr27-08, 03:45 PM
P: 277
How would you do that? I am not good with heat flux.
Please help me get started.
frasifrasi
#4
Apr27-08, 03:58 PM
P: 277
How would I set up the expression?
Astronuc
#5
Apr27-08, 04:44 PM
Admin
Astronuc's Avatar
P: 21,808
Q = Aq = -AkΔT/Δx is correct.
Heat flux = q = -k ΔT/Δx. One knows the ΔT's and the length of copper.
So q (copper) = q (steel), and the k's are different.
The 5.6 seems correct, but for 1 sec the heat (energy) should be J. W is J/s, which is power.
Does the answer input require units?
frasifrasi
#6
Apr27-08, 04:59 PM
P: 277
It requires W. I put in 5.6 and got "try again."
I don't know what to do. Shouldn't I add both q's?
frasifrasi
#7
Apr27-08, 06:24 PM
P: 277
Please! help me like a comdemned animal.
Astronuc
#8
Apr28-08, 06:37 AM
Admin
Astronuc's Avatar
P: 21,808
In order to have steady-state, what goes in one end must go out the other, i.e. the rate of heat transfer is constant along the length of the bars. The formula one used seems correct.
CrashenX
#9
May1-08, 05:56 PM
P: 1
Looks like you used a Thermal Conductivity value of 400 which is close to the value that wikipedia has. However, my book (and yours if same book p 664) uses the value of 385.0 for the thermal conductivity of copper.
...so you did it correctly. However, the answer using a thermal conductivity of 385 would be 5.39W.
vanillacreme
#10
May5-08, 06:14 AM
P: 1
How do you actually find the length?
Thanks in advance
Hootenanny
#11
May5-08, 06:23 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,781
Quote Quote by vanillacreme View Post
Thanks in advance
One would use the heat flux equation and solve for [itex]\Delta x[/itex].
Register to reply
Related Discussions
Q=mcT heat problem, were did i go wrong? Introductory Physics Homework 5
Heat flow General Physics 11
Heat Flow PDE problem Calculus & Beyond Homework 2
Heat flow Classical Physics 2
Heat capacity problem-wher am i going wrong? Introductory Physics Homework 2
