| Thread Closed |
Flux Integral Help through abnormal cone |
Share Thread | Thread Tools |
| Apr29-08, 03:50 AM | #1 |
1. The problem statement
The problem requires me to calculate the flux of F=x^2 i + z j + y k out of the closed cone, x=sqrt(y^2 + z^2) with x between 0 and 1. I am having trouble approaching this problem because most of the problems I have done give the curve as z=f(x,y) instead of x=f(y,z) and I am therefore confused as to how to apply the below equation. 2. Relevant equations For the flux through a surface given by z=f(x,y) Flux = int(F . dA) = int( [ F(x,y, f(x,y)) dot (-df/dx i - df/dy j + k) ]dxdy where df/dx is the partial derivative of f with respect to x and df/dy is the partial derivative of f with respect to y. How can I modify/apply this formula (if I even can) when given a surface as a function of x=f(y,z) as opposed to z=f(x,y) to find the flux through the horizontally opening cone? Any help would be greatly appreciated! Thanks so much. 3. The attempt at a solution I tried putting f in terms of z and going that route but ran into some nasty integrals. I tried replacing z with x and x with z (for F and f) as to simulate the same vector field and cone in a way that better applied to the given formula but once again ran into some nasty integrals. Suggestions? |
| Apr29-08, 05:23 AM | #2 |
If you have x= f(y,z) rather than z= f(x,y), then just swap x and z!
With x= f(y,z), x- f(y,z)= 0 can be treated as a level curve for a function whose gradient is then normal to the surface. That is, [itex](\vec{i}- \partial f/\partial y \vec{j}- \partial f/\partial z\vec{k})dydz[/itex] is the vector differential of surface area. You can parametrize [itex]x= \sqrt{y^2+ z^2}[/itex] by taking [itex]y= r cos(\theta), z= r sin(\theta)[/itex]- in other words, use polar coordinates but in the yz-plane rather than the xy-plane. The equation of the cone becomes x= r so the position vector for any point on the plane is [itex]\vec{r}= r\vec{i}+ r cos(\theta)\vec{j}+ r sin(\theta)\vec{k}[/itex]. Then [itex]\vec{r}_r= \vec{i}+ cos(\theta)\vec{j}+ sin(\theta)\vec{k}[/itex], [itex]\vec{r}_\theta= -r sin(\theta)\vec{j}+ r cos(\theta)\vec{k}[/itex] and the "fundamental vector product, their cross product, is [itex]r\vec{i}- r cos(\theta)\vec{j}- r sin(\theta)\vec{k}[/itex]. Since you said the "flux out of the closed cone", you want this oriented by the outward pointing normals and so the vector differential of surface area is [itex]d\vec{\sigma}= (-\vec{i}+ cos(\theta)\vec{j}+ sin(\theta)\vec{k})r dr d\theta[/itex]. In this parameterization, [itex]F(x,y,z)= x^2\vec{i}+ z\vec{j}+ y\vec{k}= + r sin(\theta)\vec{j}+ r cos(\theta)\vec{k}[/itex]. I think that gives a very simple integral. Oh, and since this is a "closed cone", don't forget to integrate over the x= 1 base. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Flux Integral Help through abnormal cone
| Flux through a Cone | Introductory Physics Homework | 12 | ||
| Electric Flux question [Surface integral] | Introductory Physics Homework | 3 | ||
| flux integral help | Calculus & Beyond Homework | 0 | ||
| double integral of mass of circular cone | Calculus & Beyond Homework | 6 | ||
| flux through surface of half a cone | Introductory Physics Homework | 2 | ||
