Accelerating Neutrons: Learn How to Use Experimental Neutrons
  • Context: Graduate
  • Thread starter Thread starter Excom
The discussion revolves around the methods of generating and utilizing neutrons for experimental purposes, focusing on the challenges and techniques involved in neutron acceleration and production. It includes theoretical and practical aspects of neutron sources, including spallation, fusion reactions, and the use of deuterons.
  • Some participants assert that neutrons cannot be accelerated directly and require a neutron source, typically involving spallation or nuclear reactions.
  • One participant describes neutron generation from nuclear reactors, fusion reactions, and spallation reactions, highlighting the broad spectrum of energies produced.
  • Another participant mentions that accelerating beams of deuterium and protons can approximate neutron beams, though they are not identical.
  • A suggestion is made about using deuterons in a thin target to produce high-energy neutron beams by stripping off the proton.
  • A participant references a paper detailing the generation of a 50 MeV neutron beam and discusses a specific facility at Los Alamos that produces higher energy neutron beams through proton spallation.
Participants express differing views on the feasibility of accelerating neutrons directly, with some emphasizing the necessity of neutron sources and others exploring alternative methods of neutron production. The discussion remains unresolved regarding the best approach to neutron generation.
Participants mention various methods and sources for neutron production, but there are unresolved details regarding the efficiency and practicality of these methods, as well as the specific types of targets used for neutron generation.
Excom
Hi, is there anyone that can tell how neutrons are accelerated for experimental use.
Hi, and welcome to PF
neutrons basically can not be accelerated. You need a neutron source. Roughly, you take huge nuclei, throw bunches of high-energy (so-called spallation) smaller guys, then somehow getting rid of anything charged you end up with only neutrons going out of your source.
http://www.mrl.ucsb.edu/~pynn/primer.pdf
Neutron beams may be generated 1) from nuclear reactors, but there is a broad spectrum of energies, 2) from fusion reactions, e.g. d+t -> alpha (3.5 MeV) + n (14.1 MeV), or 3) from spallation (p,n) reactions, in which accelerated protons are used to knock neutrons out of nuclei.
That said, what people often do is accelerate beams of deuterium (one proton + one neutron) and beams of protons, and subtract the off the proton measurement. It's not quite the same as a beam of neutrons, but it's close.
Thanks for the answers.
You can accelerate deuterons into a thin target that strips the proton, leaving a high energy neutron beam.
Do you know what kind of targets one can use for this purpose?
This paper describes generating a 50 MeV neutron beam:
http://www.fynu.ucl.ac.be/themes/he/cms/neutron_beam/neutrons-beam.html.
Higher energy neutron beams are now produced at Los Alamos. A paper with this beam is:
Phys. Rev. C 75, 031001 (2007). They describe it as:
"At the LANSCE-WNR facility at the Los Alamos National
Laboratory, a pulsed neutron beam is produced by an 800-MeV
proton beam incident on a 7.5-cm-long water-cooled tungsten
spallation target."
This neutron beam experiment finally confirms theoretical predictions from 1972.
  • · Replies 18 ·
  • · Replies 20 ·
