How Do You Find a Specific Horizontal Distance in a Projectile Problem?
To find a specific horizontal distance in a projectile motion problem, first determine the time it takes for the projectile to reach a known height (y). This is based on the independence of horizontal and vertical motions in projectile motion. Once the time is established, calculate the horizontal distance (x) traveled during that time using the horizontal velocity. This method effectively isolates the horizontal distance calculation from the overall trajectory.
  • Understanding of basic projectile motion principles
  • Knowledge of kinematic equations for vertical motion
  • Familiarity with horizontal velocity calculations
  • Ability to manipulate algebraic equations
  • Study kinematic equations for vertical motion in detail
  • Learn how to calculate horizontal velocity in projectile motion
  • Explore examples of projectile motion problems with varying heights
  • Investigate the effects of air resistance on projectile trajectories
Students in physics, educators teaching projectile motion, and anyone looking to solve specific projectile distance problems effectively.
Jason03
When you have a basic projectile problem, What is the easiest way to find a specific horizontal distance in the problem.( other than the full horizontal distance that the projectile travels)
Say you know the height (y) but want to find the distance (x).
In the basic projectile problems, the horizontal and vertical motions are independent of each other; but if along its path the particle is at the point (x,y), then that means that the time it is at x is the same time it is at y.
So if you know the height, find out at what time it is at that height; then find out how far horizontally it has gone in that time.
  • · Replies 35 ·
