What Other Point(s) Have the Same Tangent Plane?
The discussion focuses on finding the equation for the tangent plane to the surface defined by the equation z² = x² + 2y² at the point P = (1, 2, 3). The derivatives fx and fy are calculated as fx = x/(2√(x² + 2y²)) and fy = 2y/(2√(x² + 2y²)). The tangent plane is expressed as 6z = 2x + 8y. To identify other points on the surface with the same tangent plane, participants emphasize the importance of analyzing the normal vectors and the gradient of the level surface function F(x, y, z) = x² + 2y² - z² = 0.
  • Understanding of multivariable calculus, specifically tangent planes.
  • Familiarity with derivatives and gradient vectors.
  • Knowledge of level surfaces and their properties.
  • Ability to manipulate equations involving square roots and implicit functions.
  • Study the concept of tangent planes in multivariable calculus.
  • Learn about gradient vectors and their applications in determining surface properties.
  • Explore level surfaces and their significance in calculus.
  • Investigate the implications of normal vectors in relation to tangent planes.
Students and educators in mathematics, particularly those studying calculus and differential geometry, as well as anyone interested in understanding the geometric properties of surfaces and their tangent planes.
kasse
[SOLVED] Tangent plane to surface
Find an equation for the tangent plane to the surface z^2 = x^2 + 2y^2 at the point P = (1,2,3). Which other points on the surface have the same tangent plane?
2. The attempt at a solution
I find the derivatives:
fx = x/(2*sqrt(x^2 + 2y^2))
fy = 2y/(2*sqrt(x^2 + 2y^2))
The plane is given by:
z - f(1,2,3) = fx(1,2,3)(x-1) + fy(1,2,3)(y-2)
6z = 2x + 8y
So then, which other points on the surface have the same tangent plane?
I also have another question: Why does it suffice to write z = sqrt(x^2 + sy^2) instead of z = (+/-)sqrt(x^2 + sy^2) ?
First,
[tex]f_y\ne \frac{2y}{2\sqrt{x^2+ 2y^2}}[/itex]<br /> I suspect you forgot the "2" multiplying y<sup>2</sup>.<br /> <br /> You are given that the point in question is (1, 2, 3). z= 3 which is positive. That's why you can use [itex]z= \sqrt{x^2+ 2y^2}[/itex] for that point. Of course, other points, having the same tangent plane, might have z negative. In order to determine what other points on the surface have the same tangent plane, you should first determine what other points on the surface are also on that plane. Once you have those, then look at the normal vectors.<br /> <br /> <br /> <br /> By the way, for those of us who don't like square roots, it is simpler to write F(x,y,z)= x<sup>2</sup>+ 2y<sup>2</sup>- z<sup>2</sup>= 0, so the surface is a "level surface" for F. It's gradient, [itex]\nabla F= 2x\vec{i}+ 4y\vec{j}- 2z\vec{k}[/itex] is perpendicular to that surface. In particular, [itex]\nabla F(1,2,3)= 2\vec{i}+ 8\vec{j}- 6\vec{k}[/itex] gives exactly the same tangent plane.<br /> <br /> Finally, please don't use "f<sub>x</sub>", "f<sub>y</sub>", etc. without first telling us <b>what</b> f is! I was able to guess that [itex]f(x,y)= z= \sqrt{x^2+ 2y^2}[/itex] but you should have said that.[/tex]
