What Are the Equations for Nuclear Magnetic Resonance in Water?
The discussion revolves around the equations related to nuclear magnetic resonance (NMR) in water, specifically focusing on the protons of hydrogen and the magnetic field required to achieve NMR at a frequency of 60 MHz.
  • Exploratory, Assumption checking
  • Participants explore the appropriate constants to use in the equations, questioning whether to use the g-factor for protons or electrons, and whether to apply the mass of a proton or an electron in their calculations.
Some participants have provided guidance on using the correct g-factor for protons and the appropriate mass, while others seek clarification on the constants and units to ensure accurate calculations. Multiple interpretations of the problem are being discussed.
There is a focus on using SI units throughout the calculations, and participants are navigating the specifics of constants related to protons versus electrons.
steph_mil
Nuclear magnetic resonance in water is due to the protons of hydrogen. Find the field necessary to produce NMR (nuclear magnetic resonance) at 60 MHz.
These are the equations I think I'm supposed to use:
omega (subscript zero) = gamma * B (subscript zero) (omega is frequency, B is magnetic field)
B sub 0 = (omega sub zero) / (ge/2m)
I know that gamma = ge/2m, and g is the gyromagnetic ratio, but do I use g for electrons (g = 2?) and e as the electron charge? The problem states that the nuclear magnetic resonance in water is due to protons, so do I use the g for water? e can only be one thing, right (1.6 * 10^-19) and for m, do I use the mass of an electron or a proton? The equations are not complicated for this problem, but I'm confused about what constants to use (protons or electrons?). Please help!
Thanks!
ok, so I should use the g-factor for a proton that you gave. And I should use e = 1.6*10^-19, and I should use m = 9.11 X 10^-31 kg? Using that the magnetic field is equal to the frequency divided by ge/2m, I should be able to solve for the field that would produce nuclear magnetic resonance at MHz?
no should use the mass of the proton.
Use Si units all the way, then you should get the answer in Hz
you got the correct value?
  • · Replies 0 ·
