Acceleration due to Gravity problem.
The discussion revolves around the acceleration due to gravity, g, and its variation with latitude, as described by a specific mathematical model. The original poster presents a problem involving rewriting the equation in terms of powers of sin(x), calculating g for a specific latitude, and determining the percent change from the standard value of 9.8 m/s².
  • Participants discuss how to express sin(2x) in terms of sin(x) and cos(x) using trigonometric identities. There is also a query about the multiplication of sine functions and confirmation of mathematical properties.
Some participants have provided guidance on using trigonometric identities to simplify the expression for g. There is an ongoing exploration of the mathematical relationships involved, with no explicit consensus reached on the original poster's attempts.
The original poster expresses uncertainty about starting the problem and mentions a specific latitude for Portland, Maine, which may not be accurate. There is also a side note regarding notation for degrees that could affect clarity in communication.
sirajoman
Acceleration due to gravity, g, is considered to be 9.8(m/s^2). However, changes in latitude alter g according to the following model:
g = 9.78049(1 + 0.005288sin^2x-0.000006sin^2(2x))(m/s^2), where x is latitude measured in degrees.
[Side note= Hey guys i didn't know how to type in the little zero with the line across it which is the variable for degrees so i just used x, so x = zero-with-slash]
a) Rewrite g in terms of powers of sinx only
b)Find the latitude of Portland, Maine, and determine g.
c)Find the percent of change between the value calculated in part b above and the standard value of 9.8.
I seriously can't think of any! I don't even know where to begin! :(
Please excuse my sorry attempt:
a)1.g = 9.78049(1 + 0.005288sin^2x-0.000006sin^2(2x))(m/s^2)
2.g = 9.78049(sin0x +sin^2x-sin^2x)
3.g = 9.78049(sin^3x)
b)Using a calc to graph
portland = 5.4 degrees
g = 95
(im probably way off)
c)5.4/9.8 = .548
To write this as a power of sin(x) only, you just need to get rid of the sin(2x) term. Do you know a trig identity that will get you an expression for sin(2x) in terms of sin(x) and cos(x)? Then to write the cos(x) in terms of sin(x) remember 1=sin^2(x)+cos^2(x).
Dick is right. And for that 'zero with a slash in it', you mean the Greek letter 'phi' or 'theta' ;)
Thanks Dick, you helped me out a lot i just have one small question though.
Sin^2(x) * sin^2(x) = sin^4(x) ...right? :)
Or anyone else, in case Dick isn't here could answer.
That's a really small question. Sure. x^2*x^2=x^4. So sin^2(x)*sin^2(x)=sin^4(x). How could you doubt it? Were you working on the same question as sirajoman?
  • · Replies 18 ·
