Absolute Convergence of Homework Series: Real Parameter p
The series \(\sum_{n=2}^{\infty} \ln \left(1+\frac{(-1)^n}{n^p}\right)\) converges absolutely for \(p > 1\) and non-absolutely for \(1/2 < p \leq 1\). The limit comparison test indicates that the series converges when \(p\) is positive, and the absolute convergence is confirmed by analyzing the limit \(\lim_{n\rightarrow \infty} \frac{\left|\ln \left(1+\frac{(-1)^n}{n^p}\right)\right|}{\frac{1}{n^p}}\), which approaches zero for positive \(p\). The discussion highlights the need to split the series into even and odd components to further analyze convergence.
  • Understanding of series convergence tests, particularly the limit comparison test.
  • Familiarity with logarithmic functions and their properties.
  • Knowledge of absolute and non-absolute convergence concepts.
  • Basic calculus, specifically limits and series analysis.
  • Study the limit comparison test in detail to understand its application to alternating series.
  • Explore the properties of logarithmic functions in the context of series convergence.
  • Investigate the criteria for absolute and non-absolute convergence in greater depth.
  • Examine examples of series that converge conditionally versus absolutely.
Mathematics students, particularly those studying real analysis or advanced calculus, as well as educators seeking to clarify concepts of series convergence.
dobry_den
[tex]\sum_{n=2}^{\infty} \ln \left(1+\frac{(-1)^n}{n^p}\right)[/tex]
p is a real parameter, determine when the series converges absolutely/non-absolutely
I tried to do the limit [tex]\lim_{n\rightarrow \infty} \frac{\ln \left(1+\frac{(-1)^n}{n^p}\right)}{\frac{(-1)^n}{n^p}}[/tex], which is equal to one and this suggests that the series coverges if p is positive (limit comparison test). But then I'm not sure how to determine the absolute/non-absolute convergence. Could you help me please? Thanks very much in advance!
Try to split the series into two parts - the even numbers and the odd ones and see if they both converge.
i made a mistake in the first post, the limit comparison test is applicable only to non-negative series. then the limit should be like:
[tex]\lim_{n\rightarrow \infty} \frac{\left|\ln \left(1+\frac{(-1)^n}{n^p}\right)\right|}{\frac{1}{n^p}}[/tex]
which is equal to zero when p is positive. However, the lower series converges when p>1. Therefore, the original logarithm series converges absolutely for p>1.
The textbook then says that the series converges non-absolutely also for 1/2 < p <= 1. But I can't prove it - do you have any ideas?
