How to work out the drop of a ball once the velocity is known
The discussion revolves around a physics problem involving the motion of a ball bearing projected off a curved ramp and its subsequent drop from a height of 0.952 meters. The original poster is attempting to compare experimental results with theoretical predictions regarding the ball's landing distance, but is uncertain about how to calculate the time of fall and the effects of gravity on the ball's motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to separate the horizontal and vertical components of motion. Questions arise regarding the time it takes for the ball to fall a specific distance and how to calculate the horizontal distance traveled during that time.
Some participants have provided guidance on breaking down the problem into components and suggested using kinematic equations to analyze the motion. There is an ongoing exploration of the assumptions regarding the ramp's shape and the initial conditions of the ball's motion.
There is a mention of the need for more information about the ramp's shape and whether the portion where the ball leaves the ramp is horizontal. The urgency of the coursework deadline is also noted, which may influence the depth of the discussion.
red888
Hi I am currently doing physics a level and am in a spot of bother not knowing what to do next.
My data analysis is to project a ball bearing down a curved ramp and off a 0.952m desk. After obtaining the results of how far away the ball lands I am now attempting to comapre them with the theoretical results I get though I am stuck as to how I am supposed to work out that part.
P.E. = K.e
P.E. = mgh = K.E. = ½ mv²
mgh = ½ mv²
v=u+at
s=ut+1/2at²
v²=u²+2as
mgh = ½ mv²
gh = ½ v²
2gh = v²
2 x 9.8 x 0.2 = v²
3.92 = v²
√3.92 = 1.98
By placing 0.2 as a height interval I have now worked out the velocity that the ball shall travel at though this is not that helpfull as I have no idea how I am supposed to work out how quickly the ball shall drop due to gravity.
I would really appreciate some help as my textbooks have proven not very good at explaining this and my coursework is due in tommorow.
thanks,
P.E. = K.e
mgh = ½ mv²
v=u+at
s=ut+1/2at²
v²=u²+2as
mgh = ½ mv²
gh = ½ v²
2gh = v²
2 x 9.8 x 0.2 = v²
3.92 = v²
√3.92 = 1.98
thanks,
The v you have is the initial (horizontal) velocity when the ball comes off the curve and begins to fall. The equations you give, above, don't take x and y components into account. Fortunately, the components can be handled separately. How long would it take a ball, with no initial (downward) velocity, fall 0.952m? Since gravity does not affect the horizontal motion, how far will the ball move horizontally in that time?
Taking into account what has been said by HallsOfIvy, the following little ditty should be used:
s=ut+1/2at²
More information as to the shape of the ramp may be in order... Is the portion where the ball leaves the ramp horizontal i.e. parallel to the x-axis?
Make sure to break your model down into components, for instance the ramp: I assume its a diagonal line and not a curve. And the desk I assume is a straight line. And as for how far away the ball will fall. Simply use your velocity obtained as it rolls along the desk and find the distance traveled as it falls off of the desk.
btw Brendan, your name has an 'a" in it and mine has an "o" pretty kool attempt to steal my first name ;) j/k
14K
9K
