Find the temperature coefficient of resistivity for pure silicon at T=300K
The temperature coefficient of resistivity (\alpha) for pure silicon at T=300K can be calculated using the formula \alpha = \frac{1}{\rho} \cdot \frac{d \rho}{dT}, where \rho is the resistivity. The resistivity (\rho) is defined as \rho = \frac{m}{e^2 n \tau}, with m as the electron mass, e as the fundamental charge, n as the charge carrier density, and \tau as the mean time between collisions. To find \alpha, it is essential to differentiate the expression for n, the number of charge carriers per unit volume, with respect to temperature, rather than calculating n directly.
  • Understanding of semiconductor physics
  • Familiarity with the concepts of resistivity and temperature dependence
  • Knowledge of statistical mechanics, particularly occupancy probability
  • Basic calculus for differentiation
  • Study the derivation of the temperature coefficient of resistivity in semiconductors
  • Learn about the integration of density of states to find charge carrier density
  • Explore the relationship between electron mobility and resistivity
  • Investigate the effects of temperature on charge carrier concentration in silicon
This discussion is beneficial for physics students, electrical engineers, and researchers focusing on semiconductor materials and their temperature-dependent properties.
opticaltempest
I need to find the temperature coefficient of resistivity [tex]\alpha[/tex] for silicon at the temperature of [tex]T=300[/tex] Kelvin. I am supposed to assume that [tex]\tau[/tex], the mean time between collisions of charge carriers, is independent of temperature.
Temperature Coefficient of Resistivity
The temperature coefficient of resistivity [tex]\alpha[/tex] is the fractional change in resistivity per unit change in temperature. It is given below.
[tex]\alpha = \frac{1}{\rho} \cdot \frac{d \rho}{dT}[/tex], where [tex]\rho[/tex] is the resistivity of the material, and [tex]T[/tex] is the temperature in Kelvin.
Resistivity
The resistivity of a material [tex]\rho[/tex] is
[tex]\rho = \frac{m}{e^2 n \tau}[/tex], where [tex]m[/tex] is the electron mass, [tex]e[/tex] is the fundamental charge, [tex]n[/tex] is the number of charge carriers per unit volume, and [tex]\tau[/tex] is the mean time between collisions of the charge carriers.
Occupancy Probability
The occupancy probability [tex]P(E)[/tex] - the probability that an available level at energy [tex]E[/tex] is occupied by an electron is
[tex]P(E) = \frac{1}{e^{\frac{E-E_F}{kT}}+1}[/tex],
where [tex]E_F[/tex] is the Fermi energy and [tex]k[/tex] is Boltzmann's constant.
Density of States
The density of states at energy level [tex]E[/tex] is
[tex]N(E)\frac{8 \sqrt{2} \pi m^{3/2}}{h^3}E^{1/2}[/tex],
where [tex]h[/tex] is Planck's constant.
Density of Occupied States
The density of occupied states [tex]N_o(E)[/tex] is given by
[tex]N_o=N(E) \cdot P(E)[/tex]
I have been working on this problem for 4 hours with various approaches. I will list one of the more simple approaches below.
[tex]\alpha = \frac{e^2 n \tau}{m} \cdot \frac{d}{dT}\bigg[\frac{m}{e^2 n \tau}\bigg][/tex]
Since, we are assuming [tex]\tau[/tex] is independent of temperature, we can simplify the above equation to
[tex]\alpha = n \cdot \frac{d}{dT}\bigg[\frac{1}{n}\bigg][/tex]
I'm not quite sure how to calculate the number of charge carriers per unit volume [tex]n[/tex] for pure silicon at 300 Kelvin. I am assuming the expression for [tex]n[/tex] will depend on the temperature.
Can I find an expression for n by integration [tex]N_{o}(E)[/tex] over some range of energy levels?
By book states:
Suppose we add up (via integration) the number of occupied states per unit volume at T=0K for all energies between [tex]E=0[/tex] and [tex]E=E_F[/tex]. The result must equal [tex]n[/tex], the number of conduction electrons per unit volume for the metal.
They then list the corresponding integral below the paragraph:
[tex]n = \int_{0}^{E_F}{N_o(E)dE}[/tex]
The various other approaches I tried for finding n always ended up with me getting stuck with formulas involving electron mobility and effective mass - topics I have not yet covered. I'm hoping to stay away from more complicated calculations that involve the carrier mobility and effective mass if it's possible.
Thanks
You don't need to find n, only ##\frac 1n\frac{dn}{dT}##. So try differentiating the integral you have for n wrt T.
