What Is the Current Through a Resistor with Internal Battery Resistance?
The discussion revolves around calculating the current through an 8.25 ohm resistor connected to a battery with a 0.21 ohm internal resistance and a terminal voltage of 6V. The internal resistance is treated as being in series with the external resistor, allowing for the calculation of the equivalent resistance. Using Ohm's Law (V=IR), the calculated current is approximately 0.70921 A. It is emphasized that the terminal voltage includes the effects of the internal resistance, which must be considered to determine the actual electromotive force (emf) of the battery. The conversation highlights the importance of understanding internal resistance in circuit calculations.
jimmyting
[SOLVED] Battery with internal resistor
What is the current in a 8.25 ohm resistor connected to a battery that has a .21 ohm internal resistance when the potential drop across the terminals of the battery is 6V?
R_{s}=R_{1}+R_{2}...
V=IR
So I believe that the internal resistor can just be considered being in series to the other resistor, allowing me to calculate the equivalent resistor. Then with that, using V=IR, I thought I was able to get the current flowing through the circuit. I got .70921 A
Can someone correct my train of thought?
V=IR
Note that the potential drop across the terminals includes the internal resistance of the battery. The internal resistance of a battery may be depicted thus,
So the actual emf of the battery is the 6V plus the voltage drop across the internal resistance. Do you follow?
Image courtesy of Hyperphysics
Yes I do thank you for your help. Funny that you got the picture off hyperphysics, I was on there trying to read about this
No problem.
Hyperphysics is an excellent general physics reference, I'm glad that you chose to look there rather than Wikipedia :rolleyes:
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
