U-Shaped Tube Pressure Problem
by bcjochim07
Tags: pressure, tube, ushaped
bcjochim07
bcjochim07 is offline
#1
May9-08, 07:20 PM
P: 374
A U shaped tube, open to the air on both ends, contains mercury. Water is poured into the left arm until the water column is 10 cm deep. How far upward from its intitial position does the mercury in the right arm rise?
2. Relevant equations
3. The attempt at a solution
h is the height of mercury on the left side of the tube
x is the distance that the mercury moves up
101300 Pa + (1000kg/m^3)(9.80)(.10m) + (13600kg/m^3)(9.80)h= 101300 Pa + (13,600kg/m^3)(9.80)(h+x)
980 + 133280h = 133280h + 133280x
980=133280x
x= .00735m = .735cm I'm not sure if I did this correctly--this answer seems quite small
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
alphysicist
alphysicist is offline
#2
May10-08, 01:42 AM
HW Helper
P: 2,250
Hi bcjochim07,
It looks to me like you are answering the wrong question. In your equation x is the distance the top of the mercury is above the bottom of the water on the other side. However, they are asking for how much the mercury rose up above where it was before the water was poured in.
Volcano
Volcano is offline
#3
May10-08, 06:38 AM
P: 126
101300 Pa + (1000kg/m^3)(9.80)(.10m) = 101300 Pa + (13,600kg/m^3)(9.80)(x)
finally,
result: x/2
hint: you don't need to write the same pressure both side. draw a horizontal line from top of the lowest height side of most bottom liquid. And calculate the pressures for only the upper side of line which you draw.
bcjochim07
#4
May10-08, 09:59 AM
P: 374
What did you mean by x/2? I got the same number for x using your equation that I did mine. I really didn't need to put the h in.
alphysicist
#5
May10-08, 10:18 AM
HW Helper
P: 2,250
x in your equation is the distance above the bottom of the water (where the purple line is in volcano's post). Pouring in the water pushes the mercury level down on the left side, and up on the right side. You found the difference in heights between the mercury levels on the left and right side; they want the difference in height between the new level on the right and the original level on the right.
bcjochim07
#6
May10-08, 02:25 PM
P: 374
If I try to visualize how it was before the water was added, I would just distributed the mercury evenly, so would I divide my answer by two then?
Volcano
Volcano is offline
#7
May11-08, 06:55 AM
P: 126
How much down(x/2), so much up(x/2) both sides. Think this, if one side down 10cm, how much rise other side? What is the distance difference between both sides?
Register to reply
Related Discussions
Tube Pressure and Viscosity Introductory Physics Homework 5
Conceptual Pressure Question: Fluid Pressure in a U-Tube Introductory Physics Homework 1
water in a u-shaped tube Introductory Physics Homework 6
Pressure in a U-shaped Tube Introductory Physics Homework 21
Thistle tube and Pressure Introductory Physics Homework 1
