| Thread Closed |
Spin Orbit Interaction |
Share Thread | Thread Tools |
| May10-08, 01:22 PM | #1 |
(a) Consider a system composed of two electrons with orbital angular momentum quantum numbers l_1 = 4 and l_2 = 2. Give all the possible values of (i) the total orbital angular momentum quantum number L, (ii) the total angular momentum quantum number J. [8] (b) Explain what is meant by the parity of an atomic or nuclear state. Show that the state described by the wave-function [tex] $\psi= r cos \theta exp(r/2a) $ [/tex] has parity quantum number -1. 2. Relevant equations [tex] $ J=L+S $\\ $ j=l \pm s $\\ $ L^2 = l(l+1) $\\ $ P \psi = e^{i\theta}\psi $ [/tex] 3. The attempt at a solution I know this is probably extremely easy but I've been given no examples and I keep getting myself in a muddle. Are the answers for L and J suppose to come out as non integers? [tex] $ L^2 = l(l+1) $\\ $ L_1=\sqrt{20} = \pm 4.47 $ \\ $ L_2=\sqrt{6} = \pm 2.449 $\\ L = -6.919, -2.021, 2.021, 6.919 [/tex] Are the negative values valid? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May10-08, 05:50 PM | #2 |
Mentor
(i) Start by thinking about two cases:
1. the angular momentum vectors of the two electrons point in the same direction 2. they point in opposite directions What would be l (that's a lower-case "L") for the system in these two situations? Are any other values of l possible? |
| May11-08, 04:46 AM | #3 |
l would be 6, 2, -2, -4
| May11-08, 06:17 AM | #4 |
Mentor
Okay, except that l just takes on positive values or zero, so it would be 6 and 2.
Next, what other values could it have, given that the two vectors need not be aligned (i.e. not in the same direction or opposite direction)? Note: This isn't really needed here. L refers to the magnitude of the actual angular momentum. But it is much more common to refer to angular momentum simply by the quantum number, l. So for example, if l=2, we just say the orbital angular momentum is 2, rather than the actual value of [tex]\sqrt{6} \ \hbar[/tex] When I read your questions, it seems they really want the quantum numbers. These will be integers (or, if spin is included, then possibly half-integers). |
| May11-08, 06:35 AM | #5 |
Presumably when I have all the l's I just [tex]\pm 1/2 [/tex] from each one for j? For b. I understand I have to multiple it by [tex]$ e^{i\theta}$[/tex] do I need to convert the cos to terms of [tex]$ e^{i\theta}$[/tex] |
| May11-08, 07:11 AM | #6 |
Mentor
You probably should review the rules for adding two angular momenta together. It should be explained in your textbook or class lectures.
If the two L's are at some angle to each other, l will be somewhere in between 2 and 6. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Spin Orbit Interaction
| Spin orbit interaction | Advanced Physics Homework | 0 | ||
| Splitting and the spin-orbit interaction (e.g sodium-d lines) | Advanced Physics Homework | 0 | ||
| Is spin torsion interaction in the Einstein-Cartan theory? | General Physics | 0 | ||
| Spin Orbit Interaction Hamiltonian | Atomic, Solid State, Comp. Physics | 5 | ||
