Definition of Mass in Vacuum of Space
The discussion revolves around the definition of mass in the context of physics, particularly in a vacuum. Participants explore various conceptualizations of mass, its relationship to gravitational and inertial forces, and the role of mathematics in defining physical concepts.
  • Meta-discussion
  • Some participants propose that mass can be understood as gravitational mass (weight) and inertial mass (resistance to changes in motion), with general relativity suggesting their equivalence.
  • Others argue that mass can be defined in terms of energy, specifically referencing the equation E=m and its validity in various contexts, including vacuum.
  • A participant expresses a desire for a verbal definition of mass, suggesting it relates to the interactions of atomic particles, rather than relying solely on equations.
  • Another participant emphasizes the importance of mathematical definitions, asserting that without equations, claims about mass are considered useless.
  • Some participants question the adequacy of using words to define mass, suggesting that any definition can lead to further inquiries about its fundamental nature.
  • A participant humorously describes mass as a resistance to being moved due to self-interaction, indicating a more intuitive understanding.
  • There is a discussion about the relationship between physics and mathematics, with some suggesting that physicists are essentially mathematicians using mathematical language to describe physical phenomena.
  • One participant references the historical interplay between physics and philosophy, noting that foundational axioms in physics cannot be proven but can be motivated.
  • A mention of Richard Feynman's philosophy of visualizing phenomena before working out the mathematics is brought up, although there is some confusion about his affiliation.
Participants express differing views on the definition of mass, with some favoring mathematical definitions while others seek verbal explanations. The discussion remains unresolved, with no consensus on a singular definition of mass.
Participants highlight the limitations of definitions based solely on words or equations, suggesting that the nature of mass may be fundamentally complex and not easily encapsulated in a single definition.
Buckeye
Mass on Earth can be understood as weight in Kg, or units of E/C^2, but what is a viable definition that does not use the words "substance" or "matter" or some other circular term?
Astronomy news on Phys.org
I am not sure I completely understand your question. We usually refer to gravitational mass as the one subject to gravitation (giving weight on Earth), and to inertial mass as the one a body "opposes to modifications of its movement". General relativity in particular postulates that those two are equal. Nobody has ever observed that gravitational mass is any different from inertial mass : all bodies "fall at the same rate". Gravitation can thus be described in geometrical terms.
Now, E=m is the total energy of a body in its own rest frame, which is just his mass according to this equation. This is valid anywhere (with or without a gravitational field, that is also in "empty vacuum" far away from any measurable source). In an arbitrary referential, the energy has a momentum "component" corresponding to kinetic energy/quantity of movement : [tex]E^{2}=\vec{p}\,^{2}+m^{2}[/tex] (in units such that c=1).
Do you want yet another "equivalent" definition of mass, that is a "third" manifestation of mass, on top of inertial and gravitational ?
No. I do not need another equation. I need a definition in words, not equations of equalities, that explain what mass is. For example: Mass is equal to the attractive-repulsive interactions of one or more atomic particles.
Or, perhaps: Mass is due to the harmonic interaction of one set of atomic particles to another set of atomic particles.
Does that help?
Then this discussion will end belonging to GD, not HENPP :frown:
This is not a joke : words are useful scientifically to communicate only if they can be backed up by an equation. Mathematics is the only un-ambiguous way to communicate between us human beings.
Well atleast when it comes to physics, the language of physics is math after all.
Does that mean that physicists are simply mathematicians pretending to be scientists?
I don't think you're going to be satisfied. You don't want an equation, and you don't want the words that are commonly used. Fair enough, but I think you'll be disappointed.
Remember, one can take any definition of anything whatsoever and follow up with "But what is it really?" This path doesn't really go anywhere.
Please pay attention to what you post. Your logic is completely wrong. Mathematicians create the language of mathematics. Physicists use the language of mathematics to communicate between them. The equations come of course together with text in order to make the communication easier. But essentially, if you can not put your claims into equations, those are completely useless.
Using words to describe what mass is, can be termed (A resistance to being moved due to it's self interaction). In other words .. when you push something it kinda, sorta, pushes back, thusly we have mass, in a kinda sort of way. :-)
yeah, what if we have encountered something fundamental and elementary?
What if I asked the string theorists: "But what is a string made up of? What is it really?" We can go on forever..
What is your definition of science? Science is a quite broad term, http://en.wikipedia.org/wiki/Science
Physical science differs quite much from chemistry, and organic chemistry in perticular. Physical science differs from philosophy, and from archeology and so on.
Physics is an interplay between making theories, models, experiment and interprenting data. The theories are always constraint under some axioms, for instance the requirement of beeing invariant to Lorentz boosts, Gauge invariance etc. No axioms can be prooven, but they can be motivated. This sort of interplay is strongly related to philosophy, that you always must put up axioms that can't be proven in order to formulate a world view. In the old days, physics was called "Natural philosophy" and the foundators of the math we use today (calculus etc) was largely developed by people who where philosophers and experimental scientists.
A professor at the University of Berkeley and his father had the same philosophy for physics. "Draw a picture of the phenomenon and then we can work out the mathematics." Can you guess who that was?
No. Who was it?
Well it also depends on the system and the phenomenon. What if drawing a picture is impossible?
And it was R Feynman.
Feynman was at Cal Tech, not Berkeley.
Locked, this is pointless.
  • · Replies 28 ·
  • · Replies 25 ·
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 23 ·
