There is no conservation law for acids/bases, right?
  • Thread starter Thread starter Simfish
    Conservation Law
The discussion revolves around the concept of conservation laws related to acids and bases, particularly questioning whether there is a universal conservation law for these substances. Participants explore the implications of acid-base neutralization, the definition of pH, and the occurrence of acids and bases in nature.
  • One participant suggests that the pH of all acids and bases in the universe should add up to 7, but questions whether this is correct given that acids can be neutralized without bases.
  • Another participant states that there is no conservation law for acids and bases and notes that neutral pH is not necessarily 7.
  • A different participant proposes that there may be more acids than bases in nature, citing the prevalence of amino acids.
  • One reply points out that amino acids are amphoteric, complicating their classification as purely acidic or basic.
  • Another participant emphasizes the need to consider different definitions of acids and bases, such as Lewis acids and bases, and notes that conservation laws may only apply to specific systems, like the human body.
  • A hypothetical scenario is presented where the pH of a universe containing only certain gases could vary based on initial concentrations and reactions, suggesting that pH may not be uniform throughout the universe.
Participants do not reach a consensus on the existence of a conservation law for acids and bases, and multiple competing views regarding the nature and prevalence of acids and bases are expressed.
Participants mention various definitions and contexts for acids and bases, indicating that the discussion is limited by differing interpretations and the complexity of chemical interactions.
Simfish
For some reason, I've thought that there is some conservation law for acids and bases. Acids neutralize bases when added to bases, and as such, I've always thought that the pH of all possible acids/bases in the universe must add up to 7. But maybe this isn't right. After all - you don't need to neutralize acids with bases. Acids are just hydrogen ions, strictly speaking, and as such, you can neutralize acids without using up bases (and as such, you can have more acids than bases in the universe). Is this reasoning correct? And if so, does the universe have more of one than the other?
Chemistry news on Phys.org
No such law. To make things more complicated, neutral is not necessarilly 7... See water ion product page for explanation.
Not to my knowledge there isn't, I may be wrong though. Come to think of it there is probably more acids than bases, for example amino acids. They just seem to occur more commonly in nature than bases.
Amino acids are amphoteric (they have both acidic and basic "ends") so they are not necesarilly good example.
Hydrogen is not equated with acid you need to consider Lewis acid and Lewis bases.
The "Conservation" merely pertains to a system - the system of the human body has a certain pH range for example. However there is no universal law that I know of.
Imagine a universe containing only hydrogen gas, chlorine gas and oxygen gas. Before a spark there is no appropriate definition of pH. After a spark (and some burning) you have HCl and H2O which most people would say is acidic. If you add nitrogen to the mix you could also have NH3 and ammonium chloride, for example. In that case the ultimate pH is a reflection of the initial concentration of the elements and the extent of reaction. Some parts of the universe might not burn or be in chemical contact with other parts of the universe... the pH could vary spatially throughout the universe. That's a simple description of the state of our universe now.
