What Does the Scale Read When the Elevator Accelerates Upward?
The problem involves a scenario where Mandy stands on a weighing scale inside an elevator that accelerates vertically upwards. Participants discuss the forces acting on Mandy, specifically her weight and the reaction force from the scale, and how these relate to the reading on the scale during acceleration.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the definitions of weight and apparent weight, questioning how the scale measures weight and the implications of acceleration on the reading. There are discussions about the forces acting on Mandy and the relationship between her weight and the reaction force from the scale.
The discussion is active, with various interpretations being explored regarding the reading on the scale during different conditions (stationary vs. accelerating). Some participants offer clarifications about the nature of weight and the forces involved, while others question the assumptions made about the scale's operation.
Participants note the potential confusion between weight and apparent weight, as well as the assumption that the scale measures the normal reaction force. There is also mention of the scale's design and how it may affect the readings during acceleration.
Hevonen
[SOLVED] Lift, reading on the scale
Mandy stands on a weighing scale inside a lift (elevator) that accelerates vertically upwards. The forces on Mandy are her weight W and the reaction force from the scale R.
The reading of the scale is
A. R + W.
B. W.
C. R.
D. R – W.
The right answer is C, but I consider that the scale records Mandy's weight that must either weight at rest or weight at acceleration (there is two types of definition for weight; here I assume that it is weight >= weight(rest) ). So, the answer which follows this way should be A. However, it is wrong.
Please, feel free to comment.
A. R + W.
B. W.
C. R.
D. R – W.
There is only one definition of weight and that is the product of mass and acceleration due to gravity. It is easy to confuse the term weight with apparent weight (which I think you refer to as weight with acceleration), however, when we say weight we always mean the former case rather than the latter.
Let's modify the question is a little, assume that the lift is stationary. What is the magnitude of the normal reaction force?
It must be R.
But how can the reading be the same when stationary and when moving?
Let's take a step back here. When you stand on your bathroom scales, how do they measure your weight? Which force do they actually measure?
They measure my weight that is the gravitational force.
I considered that my weight = reaction force from the scale R.
Correct, so by your reasoning
Hevonen said:
A. R + W.
when the elevator is stationary the reading on the scales would be,
[tex]R + W = W+W = 2W[/tex]
You have the point, but why the outcome is the same although Mandy is accelerating (R > W)?
It seems that the scale always records the reaction force.
Hevonen said:
You got the point, but why the outcome is the same although Mandy is accelerating (R > W)?
And you've got the point: A set of scales determines your weight by measuring the reaction force. That's what I was getting at before, you cannot directly measure an object's weight. Instead, the weight must be determined by measuring another force, the reaction force :wink:.
The scale has a counterweight that experiences the same reaction force as Mandy. Therefore, the reading will only indicate the weight of Mandy.
This assumes that the scale doesn't utilize a massless spring to measure force. In that case the scale would read R+W.
Mandy stands on the scales, so I think that it's safe to assume that the type of scales she is using doesn't have a counter-weight.
You can stand on a scale (like in the doctor's office) that does have a counterweight.
No! The scale would only ever read the normal reaction force.
I see your point. Weight must be defined as the reaction force in this problem which is a function of the total acceleration applied to that which is measured. Mass is not measured... only weight. The acceleration due to gravity plus the acceleration due to the upward movement of the lift multiplied by Mandy's mass will give her weight (force). A trick(y) question indeed.
BTW, the scale (actually a balance as I described it) measures mass independent of acceleration.
Yes, it can often be confusing when this type of problem is first encountered. The solution can often seem counter-intuitive initially.
Explicitly, for the benefit of Hevonen: there are only two forces acting on Mandy, her weight (mg) and the normal reaction force (R). It is this normal reaction force that is measured by the (spring) scale to determine the weight of Mandy.
Now consider Newton's second law,
[tex]\Sum F = ma[/tex]
And in our case (defining up as positive),
[tex]R - mg = ma[/tex]
[tex]\Rightarrow R = mg + ma[/tex]
So the normal reaction force provides both the force required to accelerate Mandy and the force to stop her falling through the floor of the elevator. The key points to remember are that the scales measure the reaction force R and that the reaction force must account for both Mandy's weight and her acceleration.
I hope that helps clear things up.
I agree that a counter-weighted balance measures the 'true weight', independent of acceleration.
Your reasonings clarify the question thoroughly.
So the key to this question is that the reading in the scale = normal reaction force.
Thanks for both of you!
  • · Replies 31 ·
  • · Replies 17 ·
