Thread Closed
The Wine Clip
Share Thread Thread Tools
May14-08, 07:46 PM   #1
Mentor
The Wine Clip
Call me crazy, but I have a hard time with 'we don't know how it works, but it works great! (Buy it!)'
The Wine Clip uses principles of magnetics to improve the taste of wine as it is being poured out of the bottle....
What causes the effect has been the subject of some debate, but it is generally thought that passing a conductive fluid through a properly designed magnetic field has an effect on the polar molecules in the fluid.
http://www.thewineclip.com/cgi-bin/c...?category=home
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May14-08, 08:15 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
If you need to improve the taste of wine as it's poured from the bottle, buy better wine.
It looks like a hair clip. Hmm..and doesn't fully wrap around the bottle neck, so won't even work to stop drips.
May14-08, 08:53 PM   #3
One of its claims is:
"In contrast with most gases, oxygen is highly magnetically susceptible, and is attracted to a magnetic field."
I thought this was only true of liquid oxygen.
[ EDIT: Oh. It's paramagnetic].
As for the veracity of the product, I wouldn't put any stock in it until I saw an independent test. Their own tests and four bucks will get you a coffee at Starbuck's.
May14-08, 11:23 PM   #4
Mentor
The Wine Clip
FYI, I got this link from a spam sent by a vendor at work. They also make this, which, apparently does actually work:
When hard water is subjected to fluid dynamic changes (pressure, velocity, tern perature), dissolved minerals precipitate out of solution and migrate to the area of lowest fluid velocity typically, the walls (interior surfaces) of pipes and equipment restricting the fluid flow. This scale also acts as an insulator, dramatically reducing heat transfer efficiency.
However, when a conductive fluid passes through a magnetic field, an electromotive force is induced through the fluid perpendicular to the direction of fluid flow and the flux field. This electrical discharge through the fluid induces a positive polarity in the fluid. The magnetic flux field further causes polar water molecules to be aligned along the flux or magnetomotive force vector, thus affecting the kinetics of crystallization of the minerals in the water. Random covalent bonding of the nucleation points of these scale forming molecular clusters is reduced and, therefore, these minerals stay in suspension. They are prevented from growing so large so as to precipitate out of solution and form hard scale on the walls of pipes and equipment. This process is called "magnetic homogenization."
Basically, a magnet wrapped around a pipe will prevent dissolved ions from coming out of solution and precipitating onto the pipe.
http://www.enecon.com/products/eneflow_01.asp
Thread Closed
Thread Tools
Similar Threads for: The Wine Clip
Thread Forum Replies
Has this russian ufo clip been debunked yet? General Discussion 38
One Red Paper Clip General Discussion 17
[yahoo] Gromit clip has UK debut online Computing & Technology 0
Rubber Bands and Paper Clip Engineering Systems & Design 1
