| Thread Closed |
How do I determine volume of salt water mixture before mixing? |
Share Thread | Thread Tools |
| May20-08, 10:12 PM | #1 |
I read that when salt and water are mixed that the overall volume decreases by 2.5% (I'm not sure if this is relative to the original volume of the water or both the water and the salt). I'm not sure why this is the case and am interested in that.
Moreover, I'd like to know how one would calculate the final volume of such a mixture. I know one person who believed if a gallon of salt was dumped into 100 gallons of water that the final volume would be 101 gallons. I also know a different person who believed the final volume would be 100. Are there straightforward ways to calculate things like this? I remember doing calculations with mols in college but I'm not sure if we ever worked on mixture volumes. Thanks, techphets |
| May20-08, 10:32 PM | #2 |
I'd expect the volume of the salt water to be less than 100 gallons since the water molecules are going to solvate sodium and chloride ions (they will simply be held closer together). As for a straight forward calculation-- none that I know of off the top of my head. |
| May21-08, 10:15 AM | #3 |
Recognitions:
I remember a lab in college where we had to investigate such concepts with ethanol and water. You are going to want to research the topic of partial molar volume. http://www.stetson.edu/~wgrubbs/data...olumechen.html |
| May21-08, 10:33 AM | #4 |
Admin
The only reasonable practical approach is to use density tables. Each solution is different, density changes are different and they are quite often non-linear.
Simplest approach to calculation of the final volume is to find % w/w concentration (this is volume independent), check density tables to see what density this solution have, then to calculate volume from known total mass and density. Borek -- concentration calculator |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How do I determine volume of salt water mixture before mixing?
| Formula: final temperature when mixing water with water | Introductory Physics Homework | 5 | ||
| Titration method to determine HCl concentration in a mixture | Chemistry | 7 | ||
| Questions on salt water vs fresh water.... | General Physics | 0 | ||
| Best way to determine the weight/volume of a grain of sand/salt | Introductory Physics Homework | 2 | ||
| Fresh water eels adaptation to Salt water | Biology | 4 | ||
