What is the error in my integration by parts?
The discussion revolves around the integration of the function (x^5)/7680 multiplied by exp(-x/2) over the interval from 0 to 1. The original poster is attempting to apply integration by parts but is encountering difficulties with the calculations and the resulting values.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster describes their attempts at integration by parts, including assigning variables and calculating derivatives. They express confusion over the results obtained and question the correctness of their steps. Other participants question the signs of the terms in the integration result and suggest considering boundary conditions.
Participants are actively engaging with the original poster's calculations, raising questions about the signs of terms and the implications of substituting boundary values. There is a recognition of potential errors in the integration process, but no consensus has been reached on the specific mistakes or the correct approach.
There are indications of confusion regarding the application of integration by parts and the treatment of boundary conditions. The original poster has expressed frustration over the discrepancies in their results compared to expected values.
zxcv784
Hi,
I am trying to integrate (x^5)/7680 . exp (-x/2) dx between 0 and 1. I've had various attempts at this and this is what i have done so far...
Taken the 1/7680 outside the integration
Using integation by parts I have assigned u=x^5 and dv/dx = exp(-x/2). when i integrate exp(-x/2) i get v = -2exp(-x/2), and du/dx = 5x^4 - is this correct?
This integration results in...
-2x^5exp(-x/2) - the integral of -8x^4 . exp(-x/2)
which also has a product so i do a series of integration of parts to nock down the power each time to get the solution in terms of a x^5 + x^4 +x^3 etc...
But i mut be doing something wrong as the answer is 1.4x10^-5 and i get 0.189!
I would really appreciate some help on this integration as I've spent so long trying to figure it out and this is my last resort!
Thanks
zxcv784
sorry there is an error in my first post...
after the first integration stage i now get...
-2x^5.exp(-x/2) -integral of -10x^4 . exp(-x/2)
after continuing the integrations my final result is:
-2x^5.exp(-x/2) - 20x^4.exp(-x/2) + 160x^3.exp(-x/2) - 960x^2.exp(-x/2) + 3840x.exp(-x/2) - 7680exp(-x/2)
I have tried to substitue the boundaries into this (x=1 and x=0) but get a minus number so i must have gone wrong somewhere, any ideas?
your help on this is greatly appreciated.
zxcv784
Welcome to PF!
Hi zxcv784! Welcome to PF! :smile:
Shouldn't they all be minuses? :confused:
i don't think (because uv - -x = uv + x) so but could be wrong...
even if they were all minuses when i subsitute x=1 into it i get -7679.54 which when divided by 7680 gives -0.999 which is still way off...
any ideas?
zxcv784 said:
… even if they were all minuses when i subsitute x=1 into it …
D'uh … what about x = 0 ? :smile: :rolleyes:
D'uh...when x = 0, and you substiute it into x^n the result is 0...
I would substitute s = x/2 and then your left with
[tex] \frac{1}{120}\int_0^{1/2} s^5\,e^{-s}\,ds[/tex]
which equals
[tex] -\frac{1}{120}\left[e^{-s}\cdot P_{5}(s)\right]_0^{\frac{1}{2}}[/tex]
Where P(s) is a polynomial resulting from the integration by parts, which, I believe, can be shown to be in general,
[tex] P_n(s) = s^n + n\cdot s^{n-1} + n\cdot(n-1)\cdot s^{n-2} \ldots +n![/tex]
:wink: Even for n = 0? :wink:
  • · Replies 22 ·
  • · Replies 105 ·
13K
  • · Replies 47 ·
