How Many Bound States Exist in a Double Delta Function Potential?
The discussion revolves around the double delta-function potential described by the equation V(x)=-α[δ(x+a)+δ(x-a)]. Participants are exploring how many bound states this potential possesses and the allowed energies for specific values of α.
  • The original poster attempts to analyze the potential by dividing the region into three parts and applying boundary conditions derived from the Schrödinger equation. Some participants question how to solve the resulting equations for k and the implications of their findings regarding the number of bound states.
Participants are actively discussing the methods to find the number of bound states and the corresponding energies. There is a recognition that a graphical solution indicates only one bound state exists, but uncertainty remains about calculating the energy without numerical methods. Some guidance has been offered regarding numerical approaches, but no consensus has been reached on an analytical solution.
Participants note a lack of prior experience with problems requiring numerical solutions, raising questions about the necessity of such methods in the context of their studies.
Raze2dust
Consider the double delts-function potential
[tex] V(x)=-\alpha[\delta(x+a)+\delta(x-a)][/tex]
How many bound states does this possess? Find the allowed energies for
[tex]\alpha=\frac{\hbar^{2}}{ma^{2}}[/tex]and[tex]\alpha=\frac{\hbar^{2}}{4ma^{2}}[/tex]
I divided the region into three parts x<-a(Region 1) ; -a<x<+a(Region 2) ; x>+a(Region 3)
Since we consider bound states, E<0 and solving the SE yields
[tex]Ae^{kx} (x<-a)[/tex]
[tex]Be^{kx}+Ce^{-kx} (-a<x<a)[/tex]
[tex]De^{-kx}(x>a)[/tex]
where [tex]k=\frac{\sqrt{-2mE}}{\hbar}[/tex]
Continuity at x=-a and x=+a respectively give
[tex]A-B=Ce^{2ka}.....(1)[/tex]
[tex]D-C=Be^{2ka}.....(2)[/tex]
For this infinite potentials at points x=-a and x=+a,
[tex]\Delta(\frac{d\psi}{dx})=-\frac{2m\alpha}{\hbar^{2}}\psi(\underline{+}a)[/tex]
So these give two more BC
[tex]A(1-\frac{2m\alpha}{k\hbar^{2}})=B-Ce^{2ka}...(3)[/tex]
[tex]D(1-\frac{2m\alpha}{k\hbar^{2}})=C-De^{2ka}...(4)[/tex]
So I tried to solve these (eqns 1 to 4)and what I got was A=D and B=C
and taking A/B ratios from 1 and 3, i get [tex]ke^{4ka}=\frac{2m\alpha}{\hbar^{2}}[/tex]
And I am not able to solve this equation for k..i'd be grateful for any help :)
A breakthrough!
I tried graphical solution and its clear that there is only one bound state. But how do I calculate energy corresponding to that state without analytically solving this?
so you obtained [tex]k[/tex]?
[tex]k=\frac{\sqrt{-2mE}}{\hbar}[/tex] ?
No that's where I am stuck . How do I solve this equation for k?
[tex] ke^{4ka}=\frac{2m\alpha}{\hbar^{2}}[/tex]
By taking exp(4ka) to the other side, we can graphically find that only one solution exists. But how can we calculate that solution without using computers and numerical methods?
Raze2dust said:
No that's where I am stuck . How do I solve that equation?
ah just solve it nummerical. Newton-Rhapson method is good.
It is quite often that in physics we encounter equations that are not analytically solvable, so we have to solve them by nummerical methods. Same holds for integrals and differential equations.
ok..thanks a lot!
actually i have not encountered ant problem in griffiths book SO FAR which requires numerical solution..so i was thinking if there is any way to solve it analytically. haven't studued Newton-Raphson method yet..I'll use MATLAB may be for now..
I am not 100% sure that a solution to x*exp(x) = konstant, exists analytically.
Newton Raphson is something you do if you only have a pocket calculator. Matlab is easier if you just study on your own.
Good luck!
  • · Replies 16 ·
  • · Replies 20 ·
