Help with Questions: Circles, Vectors, Wedges & dv/dt=g-kv
  • Thread starter Thread starter mcintyre_ie
    Circles Vectors
The discussion revolves around various physics and mathematics problems, including the properties of circles, vector operations, dynamics involving a wedge, and differential equations. Participants are seeking assistance with specific questions and concepts related to these topics.
  • Mixed
  • Participants discuss the center and radius of a circle and the equations of tangents, questioning the validity of their results. They also explore vector properties, expressing uncertainty about how to prove certain identities. Additionally, there is discussion about the dynamics of a wedge and a particle, with attempts to calculate speeds and accelerations. The general solution to a differential equation is also examined, with participants sharing their approaches and expressing uncertainty about specific limits.
Some participants have provided calculations and insights into the problems, while others are still grappling with the concepts. There is a mix of correct assertions and ongoing questions, indicating a collaborative effort to clarify understanding without reaching definitive conclusions.
Participants mention constraints such as the specific definitions and terminology used in their course, which may limit their approaches to certain problems. There is also a reference to homework rules that may affect how they interpret and solve the questions.
mcintyre_ie
Hey,
I’d appreciate some help with these questions:
(c) Find the centre and radius of the circle x^2 + y^2 – x – y – 12 = 0.
Find the equations of the tangent to this circle which are parallel to the line 7x – y = 0.
Ok, so I found the line has a slope of 7, and the circle has a centre at (½ , ½) and a radius of 5/root2
Using this info, I said that the line equation is y = 7x + c and 7x – y + c = 0. The distance from (½,½) to 7x – y + c = 0 is 5/root2, and used the perpendicular distance from a point to a line formula to get a quadratic equation for C. But, I got some pretty weird answers (c = 14.18033989 and c = -8.180339887). These don’t seem right, since the answer’s aren’t supposed to go into decimals… Any ideas on where I’ve gone wrong?
(c) o, x, y and z are non-collinear vectors where o is the origin, show that:
(i) x.y = y.x
(ii) x.(y + z) = x.y + x.z
On this one, I’m totally stumped. I don’t know where to start in proving them. Any advice?
Q.4 A smooth wedge of mass 4m and slope 45 degrees is placed on a smooth horizontal surface. A particle of mass m is placed on the inclined face of the wedge. The system is released from rest.
(i) Find the speed of the mass relative to the wedge when the speed of the wedge is ½ m./s.
Ok, so I got an acceleration of 49/45 m/s^2 for the wedge and 382/[45(root2)] for the particle, used the formula v = u + at, where v = ½, u = 0, and a = (49/45) to get a time t = 45/98. I then used this t value in the equation v = u + at, getting an answer of (root8) m/s. Does that sound right?
Find the general solution to:
dv/dt = g – kv,
where g and k are constants. Hence, show that lim v (as t goes to infinity) = g/k.
Ok, so I think I got the first section right ( -1/k.ln[g – kv] = t + c ), but I’m unsure how to proceed.
Any help is appreciated.
I found the radius in c) to be 7/2 (r^(2)=1/4+12=49/4)
As for the second c) (about non-collinear vectors), use the definition of the innerproduct, and assume that:
x=(x1,x2,x3), y=(y1,y2,y3), z=(z1,z2,z3).
As to your general solution, multiply the equation with -k, and exponentiate the equation to get rid of the logarithm.
Rearranging yields the result.
I found it to be r^2 = 1/4 + 1/4 + 12.
We don't have the innerproduct on our course, only dot product and scalar product, so it has to be solved using either or both of those (or other *basic* rules.
Ok, I'll try it, but I'm not so sure about the lim part.
Thanks for the help
1. You're absolutely right about the radius.
2. The inner product is the same as the scalar product
On the scalar product, I'll do the first:
x.y=x1*y1+x2*y2+x3*y3=y1*x1+y2*x2+y3*x3=y.x, as required
  • · Replies 25 ·
  • · Replies 0 ·
