| Thread Closed |
Dipole Moment interaction |
Share Thread | Thread Tools |
| May24-08, 12:29 PM | #1 |
Consider two dipoles with moments u1 and u2 arranged as in the following diagram. Each dipole is depicted as two charges of equal magnitude separated by a distance d. The centre-to-centre separation of the two dipoles is the distance r. The line joining the two dipole centres makes an angle theta with the lower dipole (ie. q1 and -q1). Derive an expression in terms of u1, u2, theta and r which describes the potential energy of interaction of these two dipoles which is valid when d<<r. In the spirit of the hint below, your answer should not consider any (d/r)^n terms where n is greater than 2: Hint: [tex]\frac{1}{\sqrt{1-ax}}\approx1+\frac{1}{2}ax+\frac{3}{8}a^{2}x^{2}[/tex] 2. Relevant equations [tex]U(r)=\frac{kQQ}{r}[/tex] 3. The attempt at a solution I've been trying to solve this for the past hour without any luck. It centers around getting an expression for the separation between q1 and -q2, and -q1 and q2. I'm fairly certain the expression should be from Pythagoras given the hint (ie, I need to take a square root of r at some point), but I can't find one which involves d/r as also specified in the hint. If anyone could offer any pointers, I'd be most appreciative. Thanks! |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May24-08, 02:59 PM | #2 |
OK, I've got a little bit further (this seems brutal!)
I've been able to see that the separations of the charges mentioned above are: q1 & -q2: [tex]\sqrt{(d+rcos\theta)^{2}+(rsin\theta)^{2}}[/tex] -q1 & q2: [tex]\sqrt{(-d+rcos\theta)^{2}+(rsin\theta)^{2}}[/tex] Simplifying: q1 & -q2: [tex]\sqrt{d^{2}+r^{2}+2rdcos\theta}[/tex] -q1 & q2: [tex]\sqrt{d^{2}+r^{2}-2rdcos\theta}[/tex] However this quickly makes the dipole-dipole interaction energy horrible: [tex]U(r)=\frac{q_{1}q_{2}}{4\pi\epsilon_{0}}\left(\frac{2}{r}-\frac{1}{\sqrt{d^{2}+r^{2}+2rdcos\theta}}-\frac{1}{\sqrt{d^{2}+r^{2}-2rdcos\theta}}\right)[/tex] From that point I see no way to simplify the last two terms to get to a point where I can apply the Taylor expansion in the hint. I really am pulling my hair out over this now, if anyone can suggest anything I'd be ever grateful! |
| May24-08, 04:26 PM | #3 |
LOL, ok probably talking to myself here. Still playing around with this, taken it further, although I'm pretty sure my final answer here is wrong...
| Thread Closed |
| Thread Tools | |
Similar Threads for: Dipole Moment interaction
| Dipole-dipole interaction | Classical Physics | 6 | ||
| dipole moment | Introductory Physics Homework | 8 | ||
| why is the electric dipole moment of an atom zero, but the magnetic moment nonzero? | Quantum Physics | 9 | ||
| Derivation of dipole-dipole interaction energy | Advanced Physics Homework | 2 | ||
| Dipole Moment | Electrical Engineering | 0 | ||
