Thread Closed
Tricky Trig Differentiation
Share Thread Thread Tools
May30-08, 10:52 AM   #1
x = 5sin(2y +6) find dy in terms of x
2. Relevant equations
3. The attempt at a solution
dx/dy = 8 cos (2y+6)
dy/dx = 1 / (8cos(2y+6)
but according to the mark scheme the final answer is
+ or - 1 / (2 sqrt[16/x^2])
i dont see how on earth they got there :O
Can anyone? Thanks :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May30-08, 11:23 AM   #2
Recognitions:
Homework Helper Homework Help
The result they give is more directly found by inverting the original function so that it becomes an inverse-sine function: that would account for the 1/sqrt form of their answer.
As for your method, it may be better to use implicit differentiation to solve for dy/dx, rather than finding dx/dy and using the reciprocal. BTW, I don't see how you get an '8' there -- wouldn't the Chain Rule give you 10?
May30-08, 12:18 PM   #3
i though i should use the chain rule aswell but, but the mark scheme doesn't seem to use it.
here is the paper. it's question 4 ii
http://eiewebvip.edexcel.org.uk/Repo...e_20050620.pdf
here is the mark scheme
http://eiewebvip.edexcel.org.uk/Repo...s_20050618.pdf
wierd huh?
May30-08, 12:20 PM   #4
Recognitions:
Having worked this through now, I believe you have a typo here:
Quote by thomas49th View Post
x = 4 sin(2y +6) find dy in terms of x
This approach:
dy/dx = 1 / [8 cos(2y+6)]
does work and gives the same result as implicit differentiation, but only because your function f(y) is continuous in y everywhere. Such a method using reciprocal derivatives should be used with some caution...
How they get their answer is by a substitution. You know that sin(2y+6) = (x/4). How would you express cos(2y+6) in terms of x? (And I believe you also have a typo in your copy of their answer that you presented...)
May30-08, 02:08 PM   #5
yes yes your right
x = 4sin(2y +6) find dy in terms of x
+ or - 1 / (2 sqrt[16 - x^2])
substitution... ohh that sounds like a better method. how do i do that here?
y = (sin^-1(x/4) - 6)/2
is that right? What do i subistute in?
May30-08, 05:08 PM   #6
Recognitions:
I don't know what stage you are at in rules of differentiation. Have you done derivatives of inverse trig functions? The relevant rule is
d/dx [sin^-1 (u)] = [ 1 / sqrt( 1 - u^2 ) ] · (du/dx) .
For our function, u = x/4 .
Alternatively, you can use your result
dy/dx = 1 / [8 cos(2y+6)] ,
together with
sin(2y + 6) = (x/4) and
sin u = sqrt( 1 - u^2 ) ,
to get to the given answer.
Thread Closed
Thread Tools
Similar Threads for: Tricky Trig Differentiation
Thread Forum Replies
Tricky differentiation Calculus & Beyond Homework 2
Tricky trig derrivation Calculus & Beyond Homework 5
Tricky Trig Function Find the eqn Help Introductory Physics Homework 4
tricky trig substitution Calculus 6
Plz help a little tricky TRIG eqn or SOlve not sure Introductory Physics Homework 18
