QM perturbation theory: rigid diatomic molecule
The discussion revolves around quantum mechanics, specifically perturbation theory applied to a rigid diatomic molecule. The original poster presents a Hamiltonian and seeks to determine the lowest energy states and the energy correction due to an external electric field perturbation.
  • The original poster attempts to identify the lowest energy states and calculate energy corrections using perturbation theory. Some participants question the correctness of the energy values derived from the eigenvalues of the angular momentum operator.
  • Others suggest that the perturbation should not be treated as a constant and raise concerns about the implications of the angular dependence of the perturbation on the energy corrections.
  • One participant expresses uncertainty about the typical behavior of perturbations in lowering energy levels, indicating a lack of familiarity with perturbation theory.
The discussion is active, with participants providing insights and corrections regarding the energy states and the nature of the perturbation. Some guidance has been offered, particularly regarding the interpretation of the perturbation's effects on energy levels. There is no explicit consensus yet, as participants are still exploring the implications of their findings.
Participants are working under the constraints of homework rules, which may limit the depth of their discussions and the completeness of their solutions. There is an ongoing examination of assumptions related to the Hamiltonian and the perturbation's characteristics.
Pacopag
The Hamiltonian for a rigid diatomic molecule is
[tex]H_0 = {L^2 \over {2I}}[/tex]
where [tex]I[/tex] is the moment of inertia of the molecule.
(a) What are the lowest four energy states of this system?
(b) An external electric field is applied, leading to a perturbation
[tex]H_1 = ED\cos\theta[/tex]
where [tex]E[/tex] is the strength of a constant external electric field, [tex]D[/tex] is the (fixed) dipole moment of the molecule, and [tex]\theta[/tex] is the orientation of the dipole with respect to the direction of the external electric field.
Find the change in the ground state's energy to second order in perturbation theory.
First order correction is [tex]\Delta E^{(1)} = <\psi |H_1|\psi >[/tex].
Second order correction is [tex]\Delta E^{(2)} = \sum_{\psi \neq \psi '} {{|<\psi '|H_1|\psi >|^2}\over{E_\psi^{(0)}-E^{(0)}_{\psi '}}}[/tex]
(a) If we can regard the moment of inertia [tex]I[/tex] to be constant, the we can just use the spectrum of [tex]L^2[/tex]. So the lowest four unperturbed energies are
[tex]0, {\hbar^2 \over I}, {\hbar^2 \over{3I}}, {\hbar^2 \over{6I}}[/tex], corresponding to [tex]l=0,l=1,l=2,l=3[/tex].
(b) This is where things get weird for me. The ground state eigenfunction is just that for the [tex]L^2[/tex] operator. That is, the lowest spherical harmonic [tex]Y_0^0[/tex]. Also, the perturbation [tex]H_1[/tex] seems to be just a constant. So shouldn't the first order correction just shift the whole spectrum up by an amount [tex]H_1[/tex], while the second-order correction vanishes? Here I have used the orthogonality of the eigenfunctions (i.e. spherical harmonics).
Can someone please check if I'm doing this correctly?
I am way out of practise on the formalism, but I think I have some idea of how the picture is supposed to go. They tell you to find the first four energy states: I believe these are:
i) the spin zero state
ii) THREE spin-one states: up, down, and zero.
The up and down states are basically clockwise and counterclockwise about the z axis. The "zero" state combines with the other two states to give you spin about the x or y axis; all together, the three spin-one states form a set of basis states for arbitrary orientation of the spinning molecule.
The perturbation they are looking for has to have mostly the (i) state mixed with the "middle" state from (ii) to give you some preference to align with the external (presumably z-axis) electric field.
I wonder if this is helpful?
How did you get 1/3 and 1/6:confused:
The eigenvalues of [tex]L^2[/tex] are [tex]l(l+1) \hbar^2[/tex]!
H_1 is not a constant! It contains a cos theta! You simply have to do the angular integral and see what you get.
Right. It should be 3 and 6 instead of 1/3 and 1/6.
Ok. I'll give it a try and let you know. Thank you.
My answer is:
First order correction vanishes.
Second order correction is [tex]-{I \over 3}\left( {ED\over {\hbar}} \right)^2[/tex].
Does this sound reasonable? Particularly the correction being negative?
I don't really feel like texing my whole solution, but I will if you'd like.
Actually, mathematically it makes sense to me if I look at the formula for the second order correction. Is this typical that a perturbation lowers the energy? Sorry if this is a silly question. I've never done any perturbation theory before. This is my first try.
  • · Replies 0 ·
