Comparing Calcium Carbonate in 2 Shells - Help Needed
  • Thread starter Thread starter jan
This discussion focuses on conducting an experiment to compare the amounts of calcium carbonate in two different shells. The reaction of acid with carbonate, resulting in salt, water, and carbon dioxide, is highlighted as a fundamental principle for the experiment. Participants suggest that the chemistry section of the forum may provide more specialized assistance. The need for clarity and organization in posting questions is also emphasized.
  • Understanding of acid-base reactions
  • Knowledge of calcium carbonate properties
  • Familiarity with experimental design in chemistry
  • Basic laboratory skills for conducting chemical experiments
  • Research methods for quantifying calcium carbonate in shells
  • Learn about titration techniques for acid-base reactions
  • Explore the use of hydrochloric acid in carbonate analysis
  • Investigate the role of carbon dioxide in chemical reactions
Chemistry students, educators, and researchers interested in comparative analysis of calcium carbonate in biological materials.
jan
what experiment should i conduct to compare the amounts of calcium carbonate in 2 different shells...
i believe this might be of use:
acid + carbonate = salt + water + carbon dioxide
my email is janice_ling88@yahoo.com.sg or post here
pls help out...thanks
Chemistry news on Phys.org
you might be better of in the chemistry area of this sight
24K
12K
