Single slit diffraction / wave propagation
The discussion centers on the concept of single slit diffraction and its relationship to spatial frequencies. It is established that the diffraction pattern is the modulus squared of the Fourier transform of the aperture, resulting in a |sinc|^2 profile. The central spot corresponds to a spatial frequency of zero, while the first bright spot away from the central spot represents an increase in spatial frequency. Key distinctions are made between field amplitudes and intensities, particularly in the context of coherent versus incoherent light.
  • Understanding of Fourier transforms in optics
  • Knowledge of wave propagation and diffraction principles
  • Familiarity with spatial frequency concepts
  • Basic principles of coherent and incoherent light
  • Study the Fourier transform of aperture functions in optics
  • Learn about the relationship between spatial frequency and diffraction patterns
  • Explore the differences between coherent and incoherent light in diffraction
  • Investigate the optical transfer function (OTF) and its applications
Students and professionals in optics, physicists studying wave phenomena, and anyone interested in the principles of diffraction and spatial frequency analysis.
gcad
I have a couple of questions about single slit diffraction. It's not a homework exercise - just a conceptual problem. Here it is (with some introductory comments)...
I understand that the diffraction pattern from a single slit is the modulus squared of the Fourier transform of the aperture. We have all seen the picture of the slit and the resulting |sinc|^2 profile. My question is in regards to what the position/location of these fringes mean in terms of spatial frequency. I'm wondering exactly what these spatial frequencies correspond to.
I'll have a go - Is it that the sum of plane waves having different spatial frequencies (defined by the diffraction pattern) will, when summed up, equal the object (aperture)?
If so, what spatial frequency does the first bright spot away from the central spot represent? Is the wave vector the addition of the original (defined by the incident propagation direction) and the displacement vector (defined by the transverse position along the diffraction pattern)? OR does the first bright spot simply represent the inclusion of a wave with spatial frequency defined by the displacement vector, i.e. a wave traveling perpendicular to the incident wave?
comments please!
apologies for the long-windedness! :-)
Science news on Phys.org
There's a few slight misconceptions that need to be addressed first:
1) the far-field diffraction *amplitude* pattern is the Fourier transform of the field amplitude at an aperture.
2) spatial frequency is the Fourier Transform pair (dual?) to position. A single spatial frequency can be interpreted as a plane wave propagating in a particular direction. In particular, f = x/lz, where f is the spatial frequency, x the coordinate measured at the aperture, l the wavelength of light, and z the propagation distance. That expression can be turned around to measure spatial frequency in terms of angle from the aperture, but I can't seem to find it right now.
So, the central spot (on axis) corresponds to a spatial frequency of zero, and as you move away from the optical axis, the spatial frequency increases.
And, recall the above definition is for field *amplitudes*, not intensities. There's a difference when taking the coherence of the light into account- the OTF for coherent light is the pupil function, but the OTF for incoherent light is the autocorrelation of the pupil function. Since most experiments are performed using highly coherent light, there's usually no confusion.
  • · Replies 17 ·
21K
  • · Replies 20 ·
  • · Replies 34 ·
  • · Replies 17 ·
