Gaussian infinite sheet, electric field
The problem involves three parallel charged sheets with specified charge densities, and participants are tasked with determining the electric fields in the regions surrounding the sheets, as well as the potential difference between the outer sheets. The subject area is electrostatics, specifically dealing with electric fields generated by charged sheets.
  • Participants discuss calculating the electric field by considering the contributions from each sheet and whether to sum them based on their respective charge densities. Questions arise about the relevance of the distances between the sheets in calculating the electric field and potential difference.
Some participants have attempted calculations for the electric fields and potential difference, while others provide guidance on the independence of the electric field from distance and the need to consider all regions between the sheets. There is an ongoing exploration of how to approach the problem, particularly regarding the integration for potential difference.
Participants note the importance of understanding the regions defined by the positions of the sheets and how they affect the electric field calculations. There is also mention of the need to clarify the number of regions and their respective electric fields.
scholio
three thin charged sheets are placed parallel to each other as shown:
far left sheet, charge density = +10C/m^2
middle sheet, charge density = -25C/m^2
far right sheet, charge density = -10C/m^2
|<--2m (A) -->|<-----4m (B) ------>|
a) what is the electric field in regions A and B?
b) what is the difference in potential between the two outer sheets? neglect thickness of sheets
electric field at conductor surface = sigma/epsilon_o where sigma = charge density, epsilon_o = 8.85*10^-12 constant
electric flux = E (*) A where (*) is dot product, E is electric field, A is area of surface
charge enclose q_encl = sigma*A
i've only tried part a:
what does it mean in the regions A and B, do i find the electric field of each sheet and then sum them up? how do distances between sheets factor in?
find the electric flux of the far left sheet, which is circle through the center of the sheet a la cookie cutter, and since there are two sides, there are two areas
electric flux = 2AE
sigma = +10C/m^2
q_encl = 10(2A)
let electric flux = q_encl/epsilon_o
so 2AE = sigma*A/epsilon_o ---> E = sigma/ 2*epsilon_o = 10/(2(8.85*10^-12)) = 5.65*10^11 N/C
that was the electric field for the far left sheet, i would do the same thing for the middle sheet but do i need to it to the far right sheet too for part a?
electric field middle sheet = -25/(2(8.85*10^-12)) = -1.41*10^12 N/C
electric field far right sheet = -10/(2(8.85*10^-12)) = -5.56*10^12 N/C
so the electric field for a and b = electric field( far left + middle + far right) = -1.41*10^12 N/C
how do the distances between the sheets come into play? ---> the 2m and 4m
also could you give me a quick run down on what i need to do for part b.
for part b since deltaV = -[integral(E*dr)] from r_a to r_b. do i let r_a = 0m and r_b = 6m ?
thanks
The strength of the electric field outside the infinite sheet is independent of the distance from the sheet. So the distance between the sheets doesn't matter when you are computing the E field. All you have to do is make sure you add the E fields in the correct directions. And, yes, for the potential difference the distance do matter. You integrate the E field over the separation between the sheets.
part b:
since electric potential difference V_ab = -[integral(E_net*dr)] from r_b to r_a where r_b = 6m, r_a = 0m and E_net = -1.41*10^12
V_ab = -1.41*10^12(6 - 0) = -8.46*10^12 volts
correct?
You need to combine the electric field from ALL of the sheets. There are four different regions that could have four different E fields. Do they? What is it in each region? How many regions does the space between the two outer plates cover?
  • · Replies 26 ·
  • · Replies 16 ·
