Thread Closed
gaussian infinite line charge, find force
Share Thread Thread Tools
Jun9-08, 10:27 PM   #1
-----problem-------
an infinite line of charge produces an electric field of 20N/C at a point that is 3 meters from the line. the electric field points toward the line of charge
what is would be the force (magnitude and direction) on a negative 6 microcoulomb charge that is located 6m from the line?
-----equations/constants----
i want to use E = force/q_test but the equation does not factor distance of 6m in
but if i use the F = kq_1q_2/r^2 equation i don't know the second charge
what should i do?
thanks
electric field line of charge E = lambda/2pi(epsilon_o)r where lambda = 3.34*10^-9C/m, epsilon_o = 8.85*10^-12, r = 6m
capacitance C = Q/V where q is charge, v is electric potential
electric field E = F/q_test = kq/r^2 where F is force, k = 9*10^9, r is distance = 6m
force F = kq_1q_2/r^2
-----attempt-----
if i use the E = F/q_test equation it does not allow me to factor in distance/radius r of 6m
but if i use the F =kq_1q_2/r^2, i don't know what the the second charge is
what equation should i use?
thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun9-08, 10:51 PM   #2
Recognitions:
Homework Helper Homework Help
Since the electric field points toward the line of charge, the charge on the line must be negative. The electric field 20 N/C at 3 m from the line of charge is the vector sum of forces by all the charges. So you can find the field at 6 m from the line by applying inverse square law.
Jun9-08, 11:00 PM   #3
Homework Helper 2012
Recognitions:
Use "E = lambda/2pi(epsilon_o)r" to find lambda. You know E when r=3m. Once you have lambda, use the same formula to find E at r=6m. Once you have done that look back and think about how you could have treated this as a ratio problem and skipped actually solving for lambda.
Jun9-08, 11:12 PM   #4
so the inverse square law states Q/surface area = E area where Q is pt charge, since we are talking about a line charge, the surface area is the electric flux=2piLEr where L is length, E is electric field, r is radius ---> the E's cancel out though, how will i get force?
E = -6*10^-6/2piLEr where r = 6m...
http://hyperphysics.phy-astr.gsu.edu...orces/isq.html
Jun9-08, 11:18 PM   #5
Recognitions:
E's don't cancel out. L cancels out. What are you talking about? You have a formula "E = lambda/2pi(epsilon_o)r". You just have to figure out how to use it.
Jun9-08, 11:25 PM   #6
when i did it L remained, the 2pi and r canceled out.
what would having L, the length do? do i use it as distance/radius to solve for force?
F = kq_1q_2/r^2 --> do i use L for r? i still don't have the second charge?
i think i have completely missed something
Jun9-08, 11:34 PM   #7
Recognitions:
"E = lambda/2pi(epsilon_o)r", I keep putting that in quotes because you stated it. Why don't you use it? "F = kq_1q_2/r^2" only applies to point charges. Don't use it. A continuous line charge isn't a point charge.
Jun9-08, 11:46 PM   #8
i did use that equation, the one in quotes, and set that equal to the E in the inverse square law. there is only one L in the inverse square law, the 2pi and r cancel but the L remains, ultimately you end up with length L.
i tried using the inverse square law except E is on the left and right side of the equation and would get cancelled out, that is why i use the eq in quotes, which yielded a value for L.
or i could use F = qE and use E = equation in quotes, because equation in quotes contains r plus i know lambda and epsilon_o
i think that is the eq to get me the force
correct?
Jun9-08, 11:51 PM   #9
Recognitions:
Didn't I say the inverse square law doesn't apply to things that aren't point charges? Why are you using it? You don't even need it. Yes, just use "E = lambda/2pi(epsilon_o)r" and F=qE.
Jun10-08, 07:10 AM   #10
yes you were right, those eq's i got what i was looking for, F = 6.1*10^-5 N, away from the line
Thread Closed
Thread Tools
Similar Threads for: gaussian infinite line charge, find force
Thread Forum Replies
why potential of an infinite line of charge not equals to zero at r = infinite General Physics 17
Electric Potential for an Infinite line charge question Advanced Physics Homework 2
Infinite line of charge Introductory Physics Homework 4
Line of infinite charge and a gaussian sphere Introductory Physics Homework 2
net charge VS dipole moment in E field by infinite line charge General Physics 5
