Forces Mediated by Gauge Bosons: Valid Questions?
The discussion centers on the mediation of forces by gauge bosons, specifically focusing on the exchange of photons between electrons and the implications for gravitons. Participants explore whether there is a calculable number of photons exchanged during interactions, the nature of their frequencies, and the quantization of forces. The conversation touches on theoretical frameworks, calculations, and the challenges of integrating quantum field theory with gravity.
  • Some participants propose that the number of photons exchanged in an electron collision can be calculated, with contributions from all positive integer numbers of photons being summed to determine the probability amplitude.
  • Others argue that photons exchanged do not have a particular frequency, as calculations involve integrating over all photon momenta.
  • A participant notes that the method of calculating probability amplitudes does not apply to gravitons, as results tend to diverge, complicating the development of a quantum theory of gravity.
  • Concerns are raised regarding the fixed momentum of photons in tree-level diagrams, with only loop diagrams allowing for independent momenta, leading to divergences in field theory.
  • Some participants discuss the implications of including all photon momenta and the validity of mediating any number of photons in interactions.
  • One participant suggests that while intermediate momenta can be arbitrary in loop diagrams, this leads to infinities that require renormalization in quantum field theory.
  • Questions are posed about the feasibility of measuring the exact number or frequency of photons exchanged during interactions, with a consensus that such measurements are not typically possible.
Participants express a range of views on the nature of photon exchange and the implications for quantum field theory and gravity. There is no clear consensus on the validity of the initial questions posed, nor on the specifics of calculating photon contributions or measuring their properties.
Limitations include the dependence on specific definitions of momentum in tree-level versus loop diagrams, and the unresolved nature of divergences in quantum field theory calculations.
lzkelley
Forces are mediated by gauge bosons.
If, for instance, you look at a collision between 2 electrons, is there a definite/calculable number of photons exchanged? Do they have a particular frequency? Do we expect the same thing of gravitons? Does that mean the action of forces is quantized?
Or are these not valid questions?
Given the state of the two electrons before the interaction, you can calculate the probability of a particular state after the interaction. The probability is calculated by expanding the mathematical expression that represents the probability amplitude into a series, and then the terms of the series are calculated one at a time. The first term will give give you a rough idea what the amplitude is. The second will be a correction to the first, and so on. The first term can be represented by a Feynman diagram with two vertices (i.e. describing the exchange of one photon). The second term can be represented by a Feynman diagram with four vertices (describing the exchange of two photons). The third has six vertices (three photons), and so on.
So to get the correct amplitude you have to add up contributions from the exchange of every positive integer number of photons. Fortunately, it's usually sufficient to only include a few terms in the calculations.
They don't have a particular frequency. Actually, inside each term, you integrate over all photon momenta (which means that you include all frequencies).
A probability amplitude is a complex number such that when you take the square of its magnitude you get a probability.
This method doesn't work for gravitons, because the result when you calculate any of the terms is infinity. (Hm, maybe the first one is finite, but only tells us exactly the same thing as classical general relativity. I don't remember how it is). This is why people are working so hard to find a quantum theory of gravity that isn't a quantum field theory.
This is a clear and detail explanation, but there seems to be a minor problem. (Please correct me if I were wrong, thx)
The momentum of photon or photons in the tree level diagram are fixed.
Only those diagram contain loops have independent momentum, hence we
have to integrate over all possible momentum. This is also the origin of the divergence in field theory.
I think you're right. It's been a while since I actually did one of these calculations, so I forgot about that.
yes, this is correct. To the OP: the energy
and the three-momentum of the exchanged photon in a
tree-level diagram is fixed by conservation of four-momentum at the vertices.
Note that the relation E = c p that we usually have for photons is not valid here (we say that the exchnaged photon is off-shell when this relation is not valid).
ismaili said:
Only those diagram contain loops have independent momentum, hence we have to integrate over all possible momentum. This is also the origin of the divergence in field theory.
It's interesting that in 't Hooft's introduction to QFT, he says that the difference between diagrams for classical and quantum physics is that classical does not have loops:
THE CONCEPTUAL BASIS OF QUANTUM FIELD THEORY
http://www.phys.uu.nl/~thooft/lectures/basisqft.pdf
Fredrik, awesome explanation thank you.
Can you give any qualitative explanation of why its valid to include all photon momenta (for each photon)? and why ever number of mediating photons?
For a particular interaction, can measurements be made to determine the exact number/frequency of photons exchanged?
I try to give an explanation. (Everyone is welcome to correct me or discuss with me~)
First of all, we cannot determine the intermediate momenta only for those diagrams contain loops, i.e. the momenta flow in loops can be arbitrary. Moreover, one can show that loop expansion for a perturbation theory is equivalent to the \hbar expansion.
This tells us that the quantum effect allows the intermediate particles to be off-shell. From the view point of uncertainty principle, since we include all possible momenta which flowing in loops, we pretend that we know all the physics up to arbitrary high energy actually. However, QFT is just an effective theory of some unknown fundamental theory, hence the calculation of loop diagrams always gives you infinity. However, if the theory is not sensitive to high energy physics, we can cure this divergence by some tricky process called reonormalisation process, and this kind of theories are called renormalizable.
For your second question, I guess this is a no-can-do. Experimentally, what we measured are usually the cross sections for some scattering processes. A cross section can be calculated perturbatively by summing over diagrams. In each loop diagram, all possible momentum of intermediate particles contributes to the cross section.
  • · Replies 0 ·
