Can You Reformat an HP with BIOS Issues and No System on the Hard Drive?
  • Thread starter Thread starter beingben
The discussion revolves around the challenges of reformatting an old HP computer that appears to have BIOS issues and no operating system on the hard drive. Participants explore potential solutions and troubleshooting steps related to hardware recognition and formatting methods.
  • Experimental/applied
  • One participant expresses uncertainty about reformatting the HP due to suspected BIOS issues and the absence of a recognized hard drive.
  • Another participant suggests that the POST screen may be hidden and recommends pressing F8/F12/DEL during boot to access BIOS settings.
  • It is proposed that if the hard drive is not recognized, checking physical connections and jumper settings is essential.
  • A suggestion is made to use a GParted live CD to attempt to format the drive if it is detected by the BIOS.
  • One participant mentions experiencing a blue screen error when trying to format the drive in a different computer, indicating potential drive failure.
  • Another participant notes that if the drive is failing, it could lead to BSODs during the loading process of the Windows XP CD.
  • There is a mention of a recovery console that could be used to re-partition the drive if a boot CD is not available.
Participants express various viewpoints on the potential issues with the hard drive and BIOS, with no consensus on the exact cause of the problem or the effectiveness of proposed solutions. The discussion remains unresolved regarding the state of the hard drive and the best approach to reformatting.
Limitations include uncertainty about the hard drive's condition, the effectiveness of the suggested troubleshooting steps, and the potential for hardware failure affecting the reformatting process.
beingben
Ok, so i am trying to reformat my old hp for my little brothers to use. But I am not sure if i can. Its a hard-drive without a system. But i think something is wrong with my bios since it skips loading screen where you can F12 or F8 just goes to logo screen of hp. Then tells me there is no hardrive. Is there anyway to reformat this thing? And help is much need'd.
thanks, Ben
Computer science news on Phys.org
Not necessarily anything wrong with the board, the POST screen is hidden on a lot of PCs. Try just hitting F8/F12/DEL as it boots up, see if it allows you to access anything.
By "no hard drive" I'm assuming you mean it says there's no boot device?
Ways to ensure the HD is being recognized by the motherboard:
BIOS, should show up under "advanced" settings or the like... as an IDE device
Many PCS display a list of attached hardware between POST and boot, but it won't stay up long and may be hidden by the HP logo.
Boot to a CD or flash drive, and attempt to access the drive from there.
http://gparted.sourceforge.net/livecd.php
Gparted liveCD is a great bootable partitioning utility. I use it a lot at work. If the hard drive is detected, you should be able to boot to the CD and use it to reformat the drive (probably want to format it as one large NTFS partition).
If the hard drive isn't being recognized by the motherboard, make sure that it's connected. You said it's old, so it is probably IDE. It should have a power cable connected to it, from the power supply (4 pin, multi-color wires). As well as a wide, flat IDE cable connecting it to the motherboard.
If it's physically connected but not being detected, ensure that the jumpers on the drive are properly set. If it's connected and set up properly, it might just be dead. Strange noises or no vibration/noise at all is a good indicator of a dead drive.
I know it's a lot of stuff to digest, I would start by making sure it's physically connected... then try the boot CD.
lemme know how it goes
it vibes. i tried to format it in my dell, its seen, but then when it finishes to the part of where it loads everything at the bottum, it goes to a blue screen. Will try that cd later tonight i believe. Yes its an IDE
Try the gparted CD.
If you can make it that far in the winXP boot Cd, use the standard NTFS format (not quick) it'll run chkdisk which may detect bad sectors on the drive.
if you're getting a BSOD as the winXP cd loads up, the drive could be dying/dead...
Only other reason the cd would BSOD is a bad optical drive or memory, and I'm assuming the RAM/CD drive in your PC are in working order.
Sounds like the drive is either dead/dying, or whatever data is on it has been totally mutilated. Try the boot CD, but if it fails to you might have to buy a new one (or RMA this one... most drives have a 10yr or lifetime warranty).
If you don't have the boot cd I found somewhere the recover console that you could use to re-partition, it has all of the Microsoft files that are on their site but in a cd form so they work...unlike the floppy files that they have...
  • · Replies 20 ·
17K
11K
18K
12K
  • · Replies 16 ·
9K
