If all of the polar ice caps melted
  • Context: High School
  • Thread starter Thread starter gravenewworld
    Ice Polar
The discussion revolves around the implications of melting polar ice caps on sea level rise. Participants explore various aspects of this topic, including the nature of ice in polar regions, the distinction between floating and land-based ice, and the potential consequences of melting ice on global sea levels.
  • Some participants argue that melting ice should not raise sea levels because water takes up more volume as a solid than as a liquid.
  • Others clarify that significant ice masses, such as those in Antarctica, are on land and would contribute to sea level rise if melted.
  • There is a discussion about the depth and extent of Antarctic ice, with some noting it can be over a mile thick.
  • Some participants propose that the melting of ice on land would lead to a rise in sea levels, while floating ice would not affect levels when melted.
  • Concerns are raised about the rate of ice loss and how melting could accelerate due to lubrication and movement of ice sheets.
  • Some participants mention that sea levels are currently rising in various regions, influenced by factors like thermal expansion and glacial melting.
  • There are references to the Intergovernmental Panel on Climate Change (IPCC) estimates regarding future sea level rise.
  • Some participants express uncertainty about the exact contributions to sea level rise and the complexity of the factors involved.
  • Discussions include the historical context of sea level changes and the geological processes involved in land rebound after glacial periods.
Participants do not reach a consensus, as there are multiple competing views regarding the effects of melting polar ice on sea levels. Some assert that melting ice on land will raise sea levels, while others maintain that floating ice will not contribute to changes in sea level.
Participants express varying levels of understanding about the physical properties of ice and water, the geographical characteristics of polar regions, and the complexities of measuring sea level changes. Some statements reflect assumptions that may not be universally accepted.
gravenewworld
the sea level shouldn't rise? Water takes up more volume as a solid than a liquid right. So why all the fear that we will all be run over by the sea from melting polar ice cap? The sea levels shouldn't change at all right? What am I missing here?
The South pole is a continent, not just floating ice, and there is a tremendous amount of ice in the north on land, such as in Greenland.
I forget the greatest depth of the ice in Antactica, but I think it is something like a mile thick in places.
But again it is just a big chunk of floating ice right? If the entire thing melted, sea levels shouldn't rise 1 bit.
I can understand if all of the snow and ice on land actually melted, then the sea levels would rise, but if all of the chunks of ice in the ocean were to melt, sea levels shouldn't rise at all.
Antarctica has about 5 million square miles of 1 mile (average) in depth of solid ice above sea level.
It also appears that during melting, the water can carve the ice into layers and lubricate its path, so that the ice will move in large sheets rather than slowly melting, which could significantly increase the rate of loss.
No, it is sitting on land, not floating. Antarctica is a ice-covered land mass.
So what? It is still just like an ice cube in a glass of water right? I could fill a bucket a quarter up with some water and then fill it to the brim with ice, once all of the ice melted, none of the water would spill out of the bucket.
Ok, but how much of the land is actually above sea level? Do we even know? I could see how sea levels could rise if all of the ice melts that is on land above sea level.
No. It's like a funnel full of ice sitting over the glass.
The ice is not sitting in the water.
http://earthobservatory.nasa.gov/Newsroom/NewImages/Images/ICESat_AntElevation.jpg
http://earthobservatory.nasa.gov/Newsroom/NewImages/images.php3?img_id=16758
Antarctica is a continent. All that ice is sitting on a mass of land above sea level. Antarctica even has a mountain range with some peaks over 16,000 ft above sea level.
OK so if Antartica melts, sea levels rise, but since the North Pole isn't a continent there is no land underneath. Therefore if the entire ice mass of the North Pole melted, sea level wouldn't change.
Oooo, ahhhhh pretty.
Water World won't happen, but the sea level will rise.
Don't forget that as ice melts, the land beneath it rises. It's a *very* slow process, but one that is happening right now from the retreat of the last ice age.
So that we don't run out of issues :smile:
But, I think the sea level would increase (and is increasing right now; heard about this somewhere - but don't have any source).
The sea level is rising in some places and dropping in others. I've previously posted the link.
Here you go
Sea level is rising along most of the U.S. coast, and around the world. In the last century, sea level rose 5 to 6 inches more than the global average along the Mid-Atlantic and Gulf Coasts, because coastal lands there are subsiding.
Higher temperatures are expected to further raise sea level by expanding ocean water, melting mountain glaciers and small ice caps, and causing portions of Greenland and the Antarctic ice sheets to melt. The IPCC estimates that the global average sea level will rise between 0.6 and 2 feet (0.18 to 0.59 meters) in the next century (IPCC, 2007).
...Rising sea levels inundate wetlands and other low-lying lands, erode beaches, intensify flooding, and increase the salinity of rivers, bays, and groundwater tables. Some of these effects may be further compounded by other effects of a changing climate. Additionally, measures that people take to protect private property from rising sea level may have adverse effects on the environment and on public uses of beaches and waterways. Some property owners and state and local governments are already starting to take measures to prepare for the consequences of rising sea level. [continued]
http://www.epa.gov/climatechange/effects/coastal/index.html
Sea levels are rising worldwide and along much of the U.S. coast. (IPCC, 2007) Tide gauge measurements and satellite altimetry suggest that sea level has risen worldwide approximately 4.8-8.8 inches (12-22 cm) during the last century (IPCC, 2007). A significant amount of sea level rise has likely resulted from the observed warming of the atmosphere and the oceans.
According to the Intergovernmental Panel on Climate Change (IPCC), the primary factors driving current sea level rise include:
the expansion of ocean water caused by warmer ocean temperatures
melting of mountain glaciers and small ice caps
(to a lesser extent) melting of the Greenland Ice Sheet and the Antarctic Ice Sheet
Other factors may also be responsible for part of the historic rise in sea level, including the pumping of ground water for human use, impoundment in reservoirs, wetland drainage, deforestation, and the melting of polar ice sheets in response to the warming that has occurred since the last ice age.
Considering all of these factors, scientists still cannot account for the last century's sea level rise in its entirety. It is possible that some contributors to sea level rise have not been documented or well-quantified.
The rate of sea level rise increased during the 1993-2003 period compared with the longer-term average (1961-2003), although it is unclear whether the faster rate reflects a short-term variation or an increase in the long-term trend. (IPCC, 2007)
While the global average sea level rise of the 20th century was 4.4-8.8 inches, the sea level has not risen uniformly from region to region.[continued]
http://www.epa.gov/climatechange/science/recentslc.html
http://www.epa.gov/climatechange/images/slr_trends_7-apr-2006.gif
It looks to me that the data is still within the existing envelope of about +- 10mm.
There is no way to draw any conclusions based on one simple graph.
During the last ice age, glacial subsidence occurred rather quickly in geological terms, while rebound of the land that the glaciers had depressed progressed more slowly. The result is that Skowhegan, ME (~175' above current sea level) was under water, as evidenced by the blue marine clays and silt that can be found almost everywhere. The oceans probably intruded much farther inland, but I have done a lot of soils-work in that area and it is pretty amazing to think about ocean-front property so far from the (current) ocean.
On both polls, there is a lot of ice sitting on land. The Arctic may be an ocean, but there is still plenty of ice in the area (Siberia, Alaska, Canada, et cetera) that it will greatly increase sea levels.
I seem to remember an estimate of somewhere between ten a thirty five meters if all the landlocked ice melted.
And that is not even taking into account the fact that water expands as it heats up. The warmer the oceans, the greater their volume. The mass of water in the oceans is so great that seawater expansion could have a clearly noticeable effect.
The Greenland ice sheet is on a landmass too
Also, there is the water in formally "permanent" glaciers, such as in the Himalayas, that eventually makes it to the oceans. As indicated in the links from earlier, it isn't just the poles.
well even if we talk about the north pole... we can picture it as a giant iceburge and true about 90% of that ice is in the water so when it melts the water level will stay the same... but what about the 10% above the water... that will make the the oceans rise won't it? i mean 10% of the whole north pole is a whole damn lot of water!
No. Ice floats because it is less dense than water. The 10% above water is indicative of the density difference. When floating ice melts, it will not change the sea-level. Try it with a glass of water with some ice floating in it. Mark the water level and wait for the ice to melt. You'll see.
Ice forms a crystal lattice, so it reduces volume quite a bit when it melts.
EDIT: Aw, you beat me to it.
It should also be noted, that it is not as if just the ice in the Arctic Sea is going to melt. A lot of nearby landlocked glacial ice and frozen tundra is going to disappear along with it.
hmmm... i knew it was less dense and i knew water expands when frozen but i never looked at it in depth... i guess this makes sense because the amount of water the ice displaces is equal to the force holding up the ice due to buoyancy... so when the ice melts it will weigh the same as the water it displaced... hence it will make the same amount of water it displaced in the first place... interesting
Yes to first order approximation it doesn't make any difference. But the water in the ice is fresh rather than salt and colder then the sea water so it will have other effects when it melts changing the pattern of currents.
One big concern is that it is cold fresh water flowing into the artic that drags wam salt water in the gulf stream so a change in currents in the arctic can have a huge effect on the climate.
Apparently there has been a mistake.
13K
  • · Replies 42 ·
9K
  • · Replies 18 ·
  • · Replies 51 ·
32K
  • · Replies 20 ·
9K
  • · Replies 52 ·
9K
