I dont get them and they seem to easy
  • Thread starter Thread starter dralion87
The discussion revolves around a physics problem involving a block being pushed up an inclined plane with a force, where participants are tasked with finding the coefficient of kinetic friction. The subject area includes concepts of forces, energy, and friction in mechanics.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the balance of forces acting on the block, questioning how to set up the problem using conservation of energy principles versus force analysis. Some express uncertainty about plugging in numerical values and the implications of constant velocity on net forces.
The discussion is ongoing, with participants providing guidance on identifying forces and considering the work-energy principle. There is a recognition of the complexities introduced by friction and energy dissipation, but no consensus has been reached on the approach to take.
Participants note the requirement to use conservation of energy principles, which may conflict with the presence of friction and the constant velocity condition. There is also a mention of diagrams that have been drawn, indicating attempts to visualize the problem setup.
dralion87
a force of 120N pushes a 5kg block up an incline plane (20 degrees) at a constant velocity. given information find coefficient of kinetic friction between block and incline
You will want to start by looking at the forces or force components that are either pushing the block upward along the incline or pulling it downward.
Since the block is moving at constant speed along the incline, what does that tell you about the balance of forces along the incline?
i don't know help me get started u drew a picture with all of the diagrams,,,, but i don't know how to set up the problem because i have to use the conservation of energy principles.
Oh, you have to solve this using work and energy, rather than forces?
All right, what forces are acting along the incline? You need to know that in order to know what kind of work is being done.
i don't know how to plug in the numbers
Since the block is moved with constant velocity, there is no net force acting on it.
Mechanical energy won't be conserved, some if it will be dissipated into heat since there's friction.
I don't see how you're going to solve the problem using energy with the values you were given.
  • · Replies 16 ·
  • · Replies 33 ·
  • · Replies 19 ·
