Prove 4*s*k^2 = (s-m^2)^2 | Mandelstam Variables
  • Context: Graduate
  • Thread starter Thread starter Manojg
    Variables
The discussion revolves around proving the equation 4*s*k^2 = (s - m^2)^2, where s is defined as (k + p1)^2 and m^2 is the mass squared of particle p1. The context includes theoretical aspects of particle collisions and the Mandelstam variables.
  • One participant requests assistance in proving the expression involving Mandelstam variables.
  • Another participant suggests attempting the proof independently before seeking help.
  • A participant shares their attempt, noting that if k is a photon, it leads to contradictions in the equations derived.
  • Another participant clarifies that s represents the 4-momentum squared and provides a specific form of the equation assuming a particle at rest.
  • One participant argues that the expression derived from the Mandelstam definition does not equate to the proposed equation, questioning its validity.
  • Another participant cites specific papers where the equation is referenced, indicating its relevance in the context of photoproduction.
  • A participant elaborates on the derivation of the equation, discussing the cancellation of terms and the implications in the center of mass frame.
  • One participant expresses frustration over misinterpretations of their previous posts and corrects a mathematical expression they provided.
  • A later reply thanks another participant for their input, indicating ongoing engagement in the discussion.
Participants express differing views on the validity of the equation and its derivation, with no consensus reached on the correctness of the proposed proof or the interpretations of the variables involved.
Some participants highlight the importance of reference frames in the derivation, and there are indications of confusion regarding the notation and definitions used in the equations.
Manojg
Hi,
For collision: k + p1 -> q + p2, where k, p1, q and p2 are 4 Vectors of the colliding particles.
Any body show me how to prove this expression:
4*s*k*k = (s - m*m)^2, where s = (k+p1)^2 and m^2 = p1^2: mass^2 of the particle p1.Thanks.
give it a try yourself first, then we help you.
I tried it.
For an example, if k is photon then
K*k = 0 and it gives
s - m*m = 0;
k*k + p1*p1 + 2kp1 - m*m = 0;
0 + m*m + 2kp1 - m*m = 0;
kp1 = 0;
E_photon * E_p1 - P_photon * P_p1 = 0.
if p1 is at rest then
E_photon * m = 0
which is wrong.
s equals (k+p1)^2 is the 4-momentum squared. Then
[tex]s=(k+E_1)^2-{\bf k}^2[/tex].
This assumes the particle of mass m is initially at rest (lab system).
By Mandelstam's definition, [tex]s=(k+p_{1})^2[/tex] in [tex]k p_{1}\rightarrow q p_{2}[/tex] (total energy squared in the CM frame)
[tex](s-m^{2})^{2}=\left[(k+p_{1})^{2}-p_{1}^{2}\right]^{2}=\left[k^{2}+2kp_{1}\right]^{2}=4k^{2}\left[\frac{k}{2}+p_{1}\right]^{2}\neq4k^{2}s[/tex]
Why would that supposedly be right ?
Sorry for late reply.
I got this equation from papers Phy. Rev. 129, 2264(1963) (equation # 5) and Phy. Rev. 123, 1882(1961) (equation # 2.8).
Both of them being photoproduction : [tex]k^{2}=0[/tex] which is kind of useful in this context.
I understand your confusion now. Look at first row of equations in 2.4. in the CM in Phys. Rev. 123, 1882 - 1887 (1961)
[tex]k=(|\vec{k}|,\vec{k})[/tex] , [tex]p_1=(\epsilon_1,-\vec{k})[/tex]
Now it is easy to see that
[tex]s=(k+p_{1})^{2}=_{\text{CM}}(|\vec{k}|+\epsilon_1)^2-\vec{0}^2[/tex]
since the total momentum in the CM is zero (I explicitly wrote the norme squared of the null vector).
[tex](s-m^{2})^{2} = \left[(k+p_{1})^{2}-p_{1}^{2}\right]^{2} = \left[k^{2}+2kp_{1}+p_{1}^{2}-p_{1}^{2}\right]^{2} = \left[2kp_{1}\right]^{2} = 4\left[|\vec{k}|\epsilon_1+\vec{k}^2\right]^{2} = 4\vec{k}^{2} \left[\epsilon_1+|\vec{k}| \right]^{2} = 4\vec{k}^2s[/tex]
So if you followed, the [tex]k^{2}[/tex] drops by itself in the expansion of [tex]s^{2}[/tex], the [tex]p_1^{2}[/tex] cancels with [tex]m^{2}[/tex] which we put in, and we end up only with the double cross product, which we then write in the CM. This is the CM momentum you have in your mysterious 2.8 ! I would say it is confusing, because the paper should have taken care to write a bold-face k, which is really [tex]|\vec{k}|_{\text{CM}}[/tex] instead of [tex]k^{2}=\frac{(s-m^{2})^{2}}{4s}[/tex], which when interpreted as a 4-vector squared and plugged [tex]k^{2}=0[/tex] in 2.8 would give [tex]s=m^{2}[/tex], which is not true.
Note something important : we have obtained [tex](s-m^2)^2=4|\vec{k}|^2s[/tex] in the CM but this does not depend on the reference frame, so is valid anywhere.
BTW, I'm glad to see how people read my posts :cry:
humanino said:
[tex]\left[k^{2}+2kp_{1}\right]^{2}=4k^{2}\left[\frac{k}{2}+p_{1}\right]^{2}[/tex]
Wrong !
That should have been :
[tex]\left[k^{2}+2kp_{1}\right]^{2}=4k^{2}\left[\frac{k}{2\sqrt{k^2}}+\frac{1}{\sqrt{k^2}}kp_{1}\right]^{2}[/tex]
which obviously I can't do anymore.
Thanks a lot humanino.
  • · Replies 22 ·
