Non-Separable Sets: Showing A is Not Separable
  • Thread starter Thread starter Kreizhn
    Set
The problem involves a metric space (X,d) with a closed subset A. The original poster attempts to show that A is not separable by using an uncountable subset U of A, where the distance between any two points in U is at least a positive constant c. The goal is to demonstrate that A cannot contain a countably dense subset.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of assuming A is separable and explore contradictions arising from the existence of the uncountable set U. They consider the relationship between the countable dense subset S and the uncountable set U, questioning how to construct mappings between these sets.
Participants are actively engaging with the problem, exploring various approaches to demonstrate contradictions related to injective and surjective mappings. Some guidance has been offered regarding the use of the axiom of choice and the uniqueness of points in the balls around elements of U, but no consensus has been reached on the best approach.
There is a discussion about the relevance of A being closed and the implications of the distance condition on the elements of U. Participants are also considering the limitations of their current reasoning and the need for further clarification on the mappings discussed.
Kreizhn
Let (X,d) be a metric space, A a closed subset of X. Suppose we've found an uncountable subset [itex]U \subseteq A[/itex] such that [itex]\forall x,y \in U, \; d(x,y) \geq c[/itex] for some positive constant c. Show that A is not separable
A is separable if it contains a countably dense subset
For the sake of contradiction assume that A is separable. That is, there exists a countable set S such that cl(S) = A, or [itex]\forall a \in A \; \forall r>0, \; B(a;r) \cap S \neq \emptyset[/itex]
Now my idea from here is as follows. Since U is uncountable and S is necessarily countable, we can choose [itex]x \in U\setminus _S[/itex]. Then [itex]\forall r>0 \; B(x;r) \cap S \neq \emptyset[/itex] by assumption. Now I want to show a contradiction using the fact that [itex]\forall x,y \in U , \; d(x,y) \geq c[/itex]. I've been thinking about how to find a suitable r such that [itex]B(x;r) \subseteq U\setminus_S[/itex] which would cause [itex]B(x;r) \cap S = \emptyset[/itex] and give a contradiction. However, I can't find a way to guarantee that a sufficiently small r exists. Hence that idea doesn't seem to be leading anywhere, and I'm not sure what to try next.
Take r=c/4. B(u,c/4) for each u in U must contain at least one point in the countable dense subset S but only one point in U. But no s in S is contained in more than one of the balls (why?). Can you use this to construct an injective map from an uncountable set into a countable set? What's wrong with that? I'm a little disturbed because I haven't used the fact that A is closed. But not that much, because if U is a subset of X then it's always contained in a closed set. Namely X. Have I missed something subtle?
I know the reply is a little late but I've been a bit busy.
I like the idea, but I'm not too sure about the injective map from an uncountable set to a countable one. I assume we want to map U -> S injectively, but we've only shown that every s is contained uniquely to a ball around an element in u, there's no guarantee that the number of elements in [itex]B(u; \frac{c}{4} ) \cap S[/itex] is precisely one, and so I can't think of a way of creating a well-defined map.
I'm wondering if perhaps we shouldn't go in the other direction; i.e. show there's a surjective map from S to U which would also give a contradiction. We can do this since every s in S can be uniquely identified with a certain u in U, and since [itex]B(u; \frac{c}{4} ) \cap S \neq \emptyset[/itex] then for every u, an "inverse" would exist (though again not guaranteed to be a singleton set).
Am I missing something obvious that guarantees injectivity? Is there a reason why the surjectivity wouldn't work? Indeed, if the surjective argument works, I could (although not necessary) create the stronger bijective map.
It's certainly true you have to pick an s for each u. But that's what the axiom of choice is for. It's injective because if s is in B(u1,c/4), then it's not also in B(u2,c/4), so there's no chance of two elements of U mapping to the same element of S. The surjection ought to work as well. Take the subset S' of the elements of S that are contained in the balls. Now map them to U in the obvious way. Either way you get the contradiction card(S)>=card(U), I would say the choice of injecting one way or surjecting the other way are two different ways of stating the same argument.
