How to calculate work required to move an object
  • Thread starter ACasey
  • Tags
    Work
In summary, Eight books, each 4.3 cm thick with a mass of 1.7 kg, lie flat on a table. The amount of work required to stack them one on top of another is 28 J.
ACasey
Eight books, each 4.3 cm thick with a mass of 1.7 kg, lie flat on a table. How much work is required to stack them one on top of another?
w= Fdcos([tex]\theta[/tex]
For the first book, there is no work required. The displacement was zero therefore no work was required. For the second book, the d=4.31 since the book must be lifted up, but I am not sure how to calculate the force and figure the angle. Don't I need to know where the books are to begin with?
Your angle is [tex]\theta = \pi/2[/tex] here, because the force is vertical. For the force, use gravitational pull: [tex]F=mg[/tex], where [tex]g=9.8 \unitfrac[m][s^2] [/tex] is the free acceleration.
If I understand this right, for my second book, I would have 112 J. I took [tex]\pi/[/tex]/2 = 1.57 then multiplied that by 9.8*1.7 kg and got 26.16, then multiply that by the 4.3 cm and got 112 J for my final answer. then for the third book instead of multiplying it by 4.3 I would multiply it by 8.6 cm since I will have two books under it already.
I get a different result. Please write down your final expression in symbolic form.
I apologize, but I am not sure what symbolic form is. Can you please explain further?
Thank you
Your force and displacement are in the same direction so W = F*d
ACasey, symbolic form is a fancy name for writing as much as possible in letters. That way, initial energy is
[tex]E_1 = 8mgh/2 = 4mgh[/tex]
if h=4.3cm and it labels the height of center of mass. The final energy is
[tex]E_2 = 8mg \frac{8h}{2} = 32mgh[/tex]
The difference is then
[tex]E_2-E_1 = 32mgh - 4mgh = 28mgh[/tex]
This is the answer in symbolic form. Plugging in the numbers we obtain the answer in numeric form.
I guess I was unaware of how confused I am with this subject. How is energy coming into this problem? I thought the formula that I would use is force which is F= mass*gravity then multiply that by the displacement which in this case would be 4.3 c.m. for each book. Then I multiply that by the [tex]\pi[/tex]2 and that would be the solution in joule? Where am I getting lost?
If you multiply force times displacement, the result is energy. The angle is not required here, so forget about it. You can follow my solution, or if you insist on your way, then the displacement for the first book is [tex]h_1 = 0[/tex], for the second book [tex]h_2 = h[/tex], for the third [tex]h_3 = 2h[/tex] and so on, then you add all them and the result obtains. Don't forget to convert everything to SI units if you want to get joules in the end.
I'm sorry, I didn't mean to offend you. I would like to do it the correct way, but I am confused on the solution. I will get it figured out.
Thank you for your help.
You didn't offend me. There are several ways to calculate this result, doesn't matter too much which is used.
Basically this is just conservation of energy problem.
What about ...; A force of 30N does 180J of work across the floor . If the same
amount of work is done over a distance of 6m, how much force is doing work ?
1. How do I calculate the work required to move an object?
To calculate the work required to move an object, you need to multiply the force applied to the object by the distance it is moved. This can be represented by the formula W = F * d, where W is the work, F is the force, and d is the distance.
2. What units should I use to measure force and distance in the work formula?
The units for force and distance in the work formula should be consistent. Force is typically measured in newtons (N) and distance is measured in meters (m). However, you can use other units as long as they are consistent, such as pounds (lbs) for force and feet (ft) for distance.
3. Does the direction of the force affect the work calculation?
Yes, the direction of the force does affect the work calculation. Work is a scalar quantity, meaning it only has magnitude and not direction. However, the force and the distance moved must be in the same direction for the work calculation to be accurate.
4. Can I use the work formula to calculate the work required to move an object at an angle?
Yes, you can use the work formula to calculate the work required to move an object at an angle. In this case, you would need to use the component of the force that is parallel to the direction of motion.
5. Is the work required to move an object the same as the work done by the object?
No, the work required to move an object is different from the work done by the object. The work required is the amount of energy needed to move the object, while the work done is the amount of energy the object expends while moving. In most cases, the work required will be greater than the work done due to factors such as friction and air resistance.
