Solving Homework Equations Involving A & B
  • Thread starter Thread starter student 1
    Homework
The discussion revolves around two parts of a homework problem involving vector operations, specifically the scalar (dot) product of vectors A and B. The first part explores the implications of the equation A*B=-(1/2)AB, while the second part seeks to find vector B given A*B=5Ay-7Ax.
  • Mixed
  • Participants discuss the angle between vectors A and B in the first part, suggesting it could be 120 or 240 degrees. In the second part, there is uncertainty about how to start solving for B, with some participants considering the component representation of vectors.
Participants are exploring different interpretations of the problems, with some suggesting that the first part may inform the second, while others clarify that they are separate. Guidance has been offered regarding the relationship between the components of the vectors and the equations provided.
There is a mention of the teacher indicating that parts A and B are unrelated, which raises questions about the relevance of information from the first part to the second. Additionally, there is confusion about the values of Bx and By in the context of the problems.
student 1
A. If A*B=-(1/2)AB, what do you know about A and B.
B. If A*B=5Ay-7Ax, find B.
Part A I know the angle is 120 degrees in between A and B. Would I know more about the two vectors from that?
Part B. I don't know where to begin to try and answer that?
For A, it could be also be 240 degrees.
For B, think in terms of the components of the vectors. How do you represent a scalar/dot product of two vectors in terms of their components?
AxBx+AyBy with that I should be able to find my B?
Yes.
Do I use what I know in the first part of the problem as well or would this be a totally different scenario??
A better question that you must ask yourself should be, does the the answer to the first problem help you in anyway in solving the second, given that you know component-wise multiplication of vectors?
So Bx and By would simply be 1 since they are not in the problem right?
Of course not.You have to solve in the context of the upper question.
According to the teacher part A and B are unrelated, they are two separate problems, in that case bx and by would be 1 correct?
Part B tells you that A*B=5Ay-7Ax. And, of course, A*B= AxBx+ AyBy. Just compare those two equations!
Hi student 1! :smile:
(have you noticed the new X2 and X2 tags? :biggrin:)
Hint: If 5Ay - 7Ax = A.C also, what can you say about B - C? :wink:
