Thermodynamics Change in Gas Temperature along pipe
by daz18983
Tags: pipe, temperature, thermodynamics
daz18983
daz18983 is offline
#1
Jul1-08, 03:31 AM
P: 5
Nitrogen beginning at 50oC is pumped along a 30m length of Stainless Steel pipe at a flow rate of 1.5 litres per minute. The Pipeline is at ambient temperature 20oC. Find the temperature of the Nitrogen upon it leaving the end of the pipeline.
Pipe OD - 0.00635m
Pipe ID - 0.00457m
Pressure - 1bar
The following data is taken from a copy of 'An Engineering Data Book' -
Cp - Nitrogen at 20oC and 1 bar is 1.04 kJ/(kgK)
2. Relevant equations
From 'An Engineering Data Book' and 'Thermodynamics an Engineering Approach 4th Edition' i believed that i could work at the figures from the following equations -
Qdot /l = 2Pi.k.(T2-T1)/In(r2/r1)
Qdot = Heat Loss l = Length k = Thermal Conductivity T = Temperatures r = Radius
Wdot - Qdot = mdot.Cp.(T2-T1)
Wdot = Work Energy In Qdot = Heat Loss mdot = mass flow rate Cp = Specific Heat T = Temperatures
3. The attempt at a solution
using k = 15 (Which is the k of Stainless Steel)
I used Qdot /l = 2Pi.k.(T2-T1)/In(r2/r1)
which gave me a figure of 8.653 x 103 for Qdot
Then to calculate mdot i used the following -
mdot = Vdot / v
where Vdot = Volume flow rate and v = specific volume
Vdot = V / delta t
where V = Volume which is 1.5 litres and delta t = 60 seconds (take from flow rate)
therefore Vdot = 0.025 l/s = 25 x 10-5 m3/s
v = R.T1 / P
where R = Gas Constant which is 0.294 kJ/(kg.K) T1 is temperate 1 which is 323K and P is pressure which is 1 bar (1 x 105Pa)
this gives v to be 9.4962 x 10-4 m3/kg
using these mdot becomes 26.32632 x 10-3 kg/s
Now using Wdot - Qdot = mdot.Cp.(T2-T1)
I rearrage to get T2 on its own
therefore T2 = (-Qdot / mdot.Cp) + T1
note that Wdot = 0 and so has been removed
Therefore i get an answer of 50.3oC which is obviously WAY wrong??? Can someone please help me with this. Even just a point in the right direction of the correct equations. This is not a homework or coursework question this an engineering question at work and i'm not too sure where to go with it.
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Register to reply
Related Discussions
Kelvin Temperature - Celsius Temperature Change General Physics 12
Temperature of Nitrogen in a Pipe Engineering, Comp Sci, & Technology Homework 1
Temperature and frequency in an organ pipe Introductory Physics Homework 4
Thermodynamics - Temperature Classical Physics 6
