Expected Values in a Harmonic Oscillator
The discussion focuses on proving that in the nth state of a harmonic oscillator, the expected values satisfy the equations \(\langle x^2 \rangle = (\Delta x)^2\) and \(\langle p^2 \rangle = (\Delta p)^2\). It is established that \(\langle x \rangle = 0\) due to the even parity of the probability density function. The relationship \((\Delta x)^2 = \langle x^2 \rangle - \langle x \rangle^2\) simplifies to \((\Delta x)^2 = \langle x^2 \rangle\) when substituting \(\langle x \rangle = 0\). The discussion also suggests using raising and lowering operators to further analyze the expected values.
  • Understanding of quantum mechanics principles, particularly harmonic oscillators
  • Familiarity with the concepts of expected values and uncertainty in quantum systems
  • Knowledge of raising and lowering operators in quantum mechanics
  • Basic proficiency in mathematical notation used in quantum physics
  • Study the derivation of expected values in quantum harmonic oscillators
  • Learn about the mathematical representation of operators in quantum mechanics
  • Explore the implications of parity in quantum state functions
  • Investigate the role of delta functions in quantum mechanics
Students and professionals in quantum mechanics, physicists studying harmonic oscillators, and anyone interested in the mathematical foundations of quantum theory.
Domnu
Problem
Show that in the [tex]n[/tex]th state of the harmonic oscillator
[tex]\langle x^2 \rangle = (\Delta x)^2[/tex]
[tex]\langle p^2 \rangle = (\Delta p)^2[/tex]​
Solution
This seems too simple... I'm not sure if it's correct...
It is obvious that [tex]\langle x \rangle = 0[/tex]... this is true because the parity of the square of the eigenfunction is [tex]1[/tex] (in other words, the probabiliity density is an even function). Now, we know that [tex](\Delta x)^2 = \langle x^2 \rangle - \langle x \rangle ^2[/tex], but [tex]\langle x \rangle = 0[/tex], so by substitution, the desired result follows. A similar argument can be made for the momentum. [tex]\blacksquare[/tex]
You can always explicitly show that <x> = 0 in the nth state if you feel you need to show more work.
To get started try representing x in terms of the raising and lowering operators in the following line, letting the operators act on any kets to their right, and simplifying:
<n|x|n> = ... |n> is the eigenket for the nth eigenstate.You should end up with delta functions that have to be zero.
