Calculating 'Push' Force to Maintain Constant Speed
The problem involves calculating the "push" force required to maintain a constant speed of a conducting rail within a magnetic field, where an induced current is present. The subject area pertains to electromagnetism and the principles of electromagnetic induction.
  • Participants discuss the appropriate equations to use, with initial confusion regarding the relevance of charge in the context of the problem. There is an exploration of the relationship between induced current, magnetic force, and the necessary push force to maintain speed.
Some participants have provided guidance on the correct approach to calculate the magnetic force on a current-carrying wire. There is an acknowledgment of the need to counteract the magnetic force to maintain constant speed, and participants are considering the implications of directionality in their calculations.
Participants are navigating assumptions about the nature of the forces involved and the definitions of terms like "push" force and its direction. There is a mention of Lenz's law, indicating the complexity of the interactions at play.
Laurie01
A conducting rail in contact with conducting wires, oriented perpendicular to both wires, is pushed with constant speed, causing an induced current of 0.69 A. B = 0.50 T and R (Resistor) = 2.0
Calculate the "push" force necessary to maintain the rail's constant speed.
I assume I use F = q * v * b
I don't think I am using the correct equation here because there is no charge on the conducting rail. I am thinking I need to use an equation that I am not yet familiar with. I went to the chapter in my book over induction and I can't find any equations dealing with a 'push' force.
You want the magnetic force on a current-carrying wire in a magnetic field, not the force on a single charge. Read this: http://hyperphysics.phy-astr.gsu.edu/Hbase/magnetic/forwir2.html"
Ohhh! Duhh. Lol. Thanks so much! That helped.
So, F = (0.69A)(0.34m)(.50T) = .117 N
And this would be considered the "push" force? Or would it be negative since the force is acting in the opposite direction?
I assume they just want the magnitude of the force.
The induced current leads to a magnetic force on the wire. If you don't push the wire with a force opposite to the magnetic force to cancel it out, the wire will slow down due to the magnetic force. (This is the point of Lenz's law: The induced current is not "free"--you must push on the wire to maintain it.)
Thank you! That makes sense.
  • · Replies 57 ·
  • · Replies 24 ·
  • · Replies 25 ·
