Magnetic Field of 60-Turn Coil w/ 0.2m Radius & 4A Current
The magnetic field at the center of a 60-turn coil with a radius of 0.2 m carrying a current of 4 A is calculated using the formula B = (μ₀ * N * I) / (2 * r). In this equation, μ₀ represents the permeability of free space, N is the number of turns (60), I is the current (4 A), and r is the radius (0.2 m). The correct interpretation of the coil as a flat circular coil rather than a solenoid is crucial for accurate calculations.
  • Understanding of electromagnetic theory
  • Familiarity with the formula for magnetic fields in coils
  • Knowledge of the permeability of free space (μ₀)
  • Basic algebra for manipulating equations
  • Research the permeability of free space (μ₀) and its significance in electromagnetism
  • Learn about the differences between solenoids and flat circular coils
  • Explore applications of magnetic fields in electrical engineering
  • Study the effects of varying current and number of turns on magnetic field strength
Physics students, electrical engineers, and anyone interested in the principles of electromagnetism and coil design.
pooka
What is the magnetic field at the center of a 60-turn coil carrying a current of 4 A, if it has a radius of 0.2 m?
I was thinking of using the equation B=(mu0)(N/l)(current)
But I was wondering do I use the radius for l or do I use the diameter?
I think you need to consider it as flat circular coil instead of a solenoid
[tex]B=\frac{\mu_0 NI}{2r}[/tex]
thanks!
