Calculate Final Kinetic Energy of 2.0 kg Object | 30N & 15N
  • Thread starter Thread starter wikidrox
    Kinetic
The problem involves calculating the final kinetic energy of a 2.0 kg object subjected to two different forces (30N and 15N) over specified distances on a frictionless surface. The original poster seeks clarification on whether the final kinetic energy is simply the sum of the kinetic energies from each segment of motion.
  • Participants discuss the work-energy theorem and the calculation of work done by each force as a means to determine the change in kinetic energy. Some suggest a method involving finding the final velocity after each segment of motion to then calculate kinetic energy.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some have provided insights into calculating work done and the implications of using different approaches, but no consensus has been reached on a single method or solution.
Participants note the absence of friction and the need to consider the object's motion in two segments, raising questions about the assumptions made regarding acceleration and time in their calculations.
wikidrox
I need some assistance in answering this:
A force of 30N accelerates a 2.0 kg object from rest for a distance of 3.0 m along a frictionless horizontal surface. The force then changes to 15N and acts for an additional 2.0 m. What is the final kinetic energy of the object?
Would the final Kinetic Energy just be the kinetic energy of both situations added together?
work-energy theorem
Find the work done by each force. The total work done will equal the change in KE.
There's also a long way to do this without using integrals - find out how fast you're going after 5 meters and plug into your kinetic energy formula (1/2 mv^2).
The long way, you have 2 problems:
Problem 1:
From your first force, you can find acceleration resulting from that force.
Starting from your initial position (zero) and from your initial velocity (zero) and adding in your acceleration, you can find your final position. In this problem, you have your final position (3 meters) and need to solve for time.
Starting from your initial velocity (zero) and adding in acceleration over a given amount of time (which is why you needed to do the previous problem), you can find your final velocity.
If you wanted, you could determine how much kinetic energy the object has after 3 meters (but, the problem doesn't ask for this).
Problem 2:
From your second force, you can find acceleration resulting from that force.
Starting from your initial position (final position from problem #1 or 3 meters), and from your initial velocity (final velocity from problem #1), and adding in your acceleration, you can find your final position. In this case, your final position is (3 meters + 2 meters) and you need to solve for time.
Starting from your initial velocity (final velocity from problem #1) and adding in your acceleration over a given amount of time (acc and time from prob #2) you can get your final velocity.
Now, using your final velocity, you can find your kinetic energy.
Yikes, that's the long way alright. :eek:
Finding the work done by each force by direct calculation is trivial--No need for any integrals.
But, the more ways you can do a problem, the better your understanding.
Yeah, you're right.
But, then, I'll go to any length to avoid work :biggrin:
Good one! :biggrin:
  • · Replies 16 ·
