Linear momentum conservation - rocket
The problem involves a two-ended rocket system consisting of a central block and two side blocks, with explosions propelling the side blocks in opposite directions. The scenario is set on a frictionless surface, and the task is to determine the velocity of the central block and its position after a series of explosions.
  • Participants discuss the sequence of events involving the explosions and their effects on the blocks' velocities. There is uncertainty about the initial and final momentum calculations, and participants question the interpretation of the problem's wording.
Some participants have attempted to set up momentum equations based on the explosions, while others are clarifying the relationships between the velocities of the blocks. There is an ongoing exploration of the implications of the explosions on the system's momentum, with hints provided to guide the reasoning process.
There is confusion regarding the timing of the explosions and the resulting velocities of the blocks. Participants are also grappling with the implications of conservation of momentum in the context of the problem's setup.
Ready2GoXtr
A two-ended "rocket" that is initally stationary on a frictionless floor, with its center a the origin of an x axis. The rocket consists of a central block C(of mass M = 6.00kg) and blocks L and R (each of mass m = 2.00kg) on the left and right sides. Small explosions can shoot either of the side blocks away fro mblock C and along the x axis. Here is the sequence: (1) At time t = 0, block L is shot to the left with a speed of 3.00 m/s relative to the velocity that the explosion gives the rest of the rocket. (2) Next at the time t = .80 s, block R is shot to the right with a speed of 3m/s relative to the velocity that block C then has. At t = 2.80s, what are the (a) velocity of block C and (b) the position of its center?
http://ready2goxtr.googlepages.com/Problem943.jpg
Pi = Pf
Pi = m1v1 + m2v2 + m3v3 Pf = m1v1f + m2v2f + m3v3f
I don't really understand what's happening in the problem
Hi Ready2GoXtr! smile:
The question is rather badly worded :frown:, but I think it means that the first explosion is between L and C, and the second between R and C, so that each explosion pushes both blocks away from each other. :smile:
alright so should I set PI = to 0 seconds and PF = to .80? seconds
Not following you. :confused:
Pi = 0, yes … but P is constant, so Pf = 0 also.
Hint: after the first explosion, v2 = v3, and they are both 3 m/s different from v1 :smile:
You mean at t = .80 seconds v2 = v3?
Assuming that v2 is the intial velocity of R block and v3 is the initial velocity of the C block, that statement is true. (Note: Initial means before the R block is shot off).
No, I mean between t = 0 and .80 …
the explosion is between blocks 1 and 2, so block 2 pushes block 3, and therefore blocks 2 and 3 have the same velocity (v2 = v3), until the second explosion. :smile:
so could i say that m1v1i = 2kg * 3m/s?
Nooo …
Going to bed now … :zzz:​
Okay i think ima just sskip it, don't know how to do the question
I decided to give it another try. since the momentums have to equal each other, I set m1v1 =- (m2+m3)v2 v2 = .75 m/s i
then i just decided. well what would have it been if it was just m1 and m2
m1v1 = m2v2 v2 = -1 then i took -1 + .75 = equal final velocity which is -.15 m/s
For part b that was easy
vit = .6m then vft = -.42 added them .18 m
Hi Ready2GoXtr! :smile:
No, those aren't the results I get.
It's difficult to tell unless you show your full working, but I think you subtracted 1 from 3 instead of adding.
Hint: You need two positive speeds (one left, one right) which add up to 3, and one is 4 times the other. :smile:
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 38 ·
18K
