How does the magnetic field affect the speed of a particle Experiment
The discussion focuses on planning an experiment to investigate how a magnetic field influences the speed of a charged particle, utilizing the equation qvB = mv². The participant considers using a current-carrying conductor as a relevant method for the experiment. Suggestions for appropriate apparatus and alternative experimental setups are sought, emphasizing the need for logical and accessible solutions.
  • Understanding of electromagnetic theory, specifically the Lorentz force.
  • Familiarity with the equation qvB = mv² and its components.
  • Knowledge of basic laboratory apparatus for physics experiments.
  • Experience with conducting experiments involving charged particles and magnetic fields.
  • Research the use of a cathode ray tube (CRT) to visualize the effect of magnetic fields on charged particles.
  • Explore the principles of electromagnetic induction and its relation to particle speed.
  • Investigate the setup and execution of a Helmholtz coil experiment for uniform magnetic fields.
  • Learn about data analysis techniques for interpreting results from particle speed experiments.
Students in physics, educators planning experiments, and researchers interested in the effects of magnetic fields on charged particles.
souseta
I am required to plan an experiment on how does the magnetic field affect the speed of a particle.
qvB=m v2
I have thought of using the experiment on current carrying conductor. Do you think it is relavent? Is there other solutions?
What apparatus is available to you?
I can use any apparatus as long as it is logical and not too advanced
