Counting Raindrops in Wichita, KS
  • Context: High School
  • Thread starter Thread starter moe7404
    Counting
The discussion revolves around estimating the number of raindrops in one inch of rain collected in a one-inch diameter tube. Participants explore various methods for measuring rainfall, considering the variability in raindrop sizes and the implications for accuracy in measurement.
  • Experimental/applied
  • Some participants propose calculating the number of raindrops based on the average volume of a drop, but note that there is no standard volume for a water drop.
  • One participant suggests a new method for measuring rainfall using a plexiglass box with beams to count broken beams, raising questions about the utility of counting drops versus measuring total water volume.
  • Another participant questions the practicality of knowing the number of raindrops, suggesting that measuring the total height of water might be more relevant.
  • Concerns are raised about the variability in raindrop sizes, with some participants noting that drops can range significantly in diameter depending on weather conditions.
  • A suggestion is made to calibrate the proposed device against a standard rain gauge to account for detection errors and variations in drop size.
  • One participant mentions alternative methods for measuring rainfall, such as using a sensitive scale to measure the weight of collected drops.
  • Another participant shares an anecdote about estimating drop size using steam in a shower, suggesting that an average of around 25 drops equals 1ml.
Participants express a mix of ideas and concerns, with no consensus on the best method for measuring rainfall or the relevance of counting raindrops versus measuring total volume. The discussion remains unresolved regarding the effectiveness of the proposed measurement techniques.
Limitations include the lack of a standard volume for raindrops, the variability in drop sizes, and the potential for systematic errors in detection methods. The discussion also highlights the assumptions made about raindrop uniformity and the challenges in accurately measuring rainfall.
moe7404
moe in wichita ks
how many drops are in 1 inch of rain on a 1 inch dia tube?
of course iam guessing that all rain drops are the same size, which most likely they are not. sounds the like this is going to have a lot averages in the answer.
The answer comes down to: what is the volume of an average water drop? I don't know if there is a scientifically accepted, standard water-drop volume. You might try an online search and see what you can find.
The container volume is
[tex] \frac{\pi}{4} \ in^3 = 0.785 \ in^3<br /> = 12.9 \ cm^3 = 12.9 \ ml[/tex]
so to get the number of drops, divide the container volume by the average volume of a drop.
moe in wichita ks
thanks to redbelly98 for crunching some numbers, that's a big help.
the reason i am asking this Q is that i am thinking of making a different way to measure rain fall. my idea is have a square plexaglass box with a set beams going across two different ways, and count the number of broken beams in a certin length of time. what think? thanks for any help
moe7404 said:
moe in wichita ks
That would certainly give you a more accurate measure of how many rain drops fall, assuming of course that the 'mesh' of beams is sufficiently fine. However, I'm not sure that knowing how many raindrops fell in addition to the total volume of water would be more useful than simply measuring the total height of water.
I'm also intrigued as to why you would chose a cubic box over a cylindrical tube?
Because his two sets of beams are perpendicular. He's making a square grid.
moe7404 said:
moe in wichita ks
As Hoot points out, of what use to anyone is the number of raindrops? Surely the volume of water over time is the only relevant factor, or are you looking to offer this as a new feature in rainfall measurements?
BTW, how do you account for a raindrop breaking more than one beam (while still ensuring the grid's fine enough to not let any drops fall through the gaps)?
"I'm not sure that knowing how many raindrops fell in addition to the total volume of water would be more useful than simply measuring the total height of water."
"...of what use to anyone is the number of raindrops..."
maybe he doesn't want to empty the rain gage -
Such a gauge would give you an "instantaneous" reading of the rainfall rate. It would also allow one to measure very small rainfalls such as 0.01".
Moe, rather than calculating the number of raindrops based on some assumed average volume, it would be better to calibrate the device after building it. Just test it against a standard raingauge, and see how many drops are counted vs. the height of the water in the gauge. This way, any systematic errors get accounted for, eg. what if only 90% of the drops are detected?
Rain drop size varies a LOT, in a mist the drops are tiny much less then a mm. In a drizzle they tend to vary but generally bigger then a mist but smaller then rain. When a major storm dumps the drops can be huge, several mm in dia. Not sure how you can use a drop count for tracking rainfall when there is so much variation.
moe in wichita ks
i thank you all for your ideas. my first idea was just to have a different way to measure rain fall. if it could be made to work its main advantage would be measuring would be done second by second, and not having a moving part. but you points are well taken, the main one being that rain drops are all kinds of sizes. i thank you all for your ideas. i really love this site. thanks
You could get some piece of metal or plastic and when it rains pick up the water with an eyedropper. Or better yet get a very sensitive scale and measure weight as some drops fall on it. Then you can easily get volume through mass and density.
Huh. Now that's a new feature. :!) The acme of rainfall measurement science today is only able to measure after-the-fact.
moe7404 said:
moe in wichita ks
My suggestion for finding the most common size for a drop of water, would be to have a flat surface (like the ceiling of a shower) if you use steam in the shower, water will build up and at a point the volume builds and breaks away, producing a drop based on density.
I don't remember the web sites, but more than one agreed that an average of around 25 drops would equal 1ml.
Ron
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 20 ·
